VBA Edit BOM
VBA Edit BOM
Message 1 of 16
VBA Edit BOM
I'm trying to write a VBA maacro, which when launched in an assembly will go  through the BOM and modify the part number of each component.
Some components have "." in the part number, I need to remove "." and everything after it.
I can't figure out where the "part number" property resides
Public Sub CleanWireBOM()
    Dim asmDoc As AssemblyDocument
    Set asmDoc = ThisApplication.ActiveDocument
    Dim oBOM As BOM
    Set oBOM = asmDoc.ComponentDefinition.BOM
    oBOM.StructuredViewFirstLevelOnly = False
    oBOM.StructuredViewEnabled = True
    Dim oStructuredBOMView As BOMView
    Set oStructuredBOMView = oBOM.BOMViews.Item("Structured")
    Dim oBOMRow As BOMRow
    For Each oBOMRow In oStructuredBOMView.BOMRows
        Dim oCompDef As ComponentDefinition
        Dim PartNum As String
        PartNum =  ?????
    Next
End Sub
Replies (15)
Message 2 of 16
bradeneuropeArthur
this should do:
    Dim oBOM As BOM
    Dim a As Document
    Set a = oBOMRow.ComponentDefinitions.Item(1).Document
    MsgBox a.FullDocumentName
    Dim p As PropertySet
    Set p = a.PropertySets.Item(3)
    Dim pr As Property
    Set pr = p.Item("Part Number")
    Dim arr() As String
    On Error Resume Next
    arr = Split(pr.Value, ".", -1)
    Err.Clear
    pr.Value = arr(0)
    a.Save
    Next
End Sub
Because you asked the BOM iteration.
This can be different the all ref documents!!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 16
MechMachineMan
Easier to just iterate through the refdocs...
Sub Main()
    Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
    Dim oRefDoc As Document
    For each oRefDoc in oDoc.AllReferencedDocuments
If oRefDoc.isModifiable = True Then oPN = oRefDoc.PropertySets("Design Tracking Properties")("Part Number").Value
Dim arr() As String
On Error Resume Next arr = Split(oPN, ".", -1)
oPN = arr(0) Err.Clear
oRefDoc.PropertySets("Design Tracking Properties")("Part Number").Value = oPN
End if
Next
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 4 of 16
Thank you for the quick responses. The code works well for regular parts & assemblies but not for cable/harness (which is what I was hoping to use it for).
My assembly consists of:
Connector1
Connector2
Cable1
 -> Wire1
 -> Wire2
 -> Wire3
Cable1 is set to "Phantom" in the BOM to promote the individual wires.
When I run the code with a debug statement
Debug.Print oBOMRow.ItemNumber, "-", pr.Value, vbCr
I get:
1             -             C1
2             -             Cable1
3             -             Cable1
4             -             Cable1
I guess the individual wires don't have their own "documents". So how can I access their part numbers?
Same thing happens if I add a "Virtual" component to the top level assembly. The code doesn't pick up it's part number.
I have tried setting the BOM to both "Structured" and "Parts Only" but the results is the same.
Message 5 of 16
smilinger
Try this then:
Sub CleanWireBOM()
    Dim oBom As BOM
    Set oBom = asmDoc.ComponentDefinition.BOM
    oBom.StructuredViewEnabled = True
    oBom.StructuredViewFirstLevelOnly = False
    Dim oBOMView As BOMView
    Set oBOMView = oBom.BOMViews(2)
    Dim compDef As ComponentDefinition
    Dim doc As Document
    Dim row As BOMRow
    Dim prop As Property
    For Each row In oBOMView.BOMRows
        Set compDef = row.ComponentDefinitions(1)
        Set doc = compDef.Document
        If compDef.Type = kVirtualComponentDefinitionObject Then
            Set prop = compDef.PropertySets("Design Tracking Properties")("Part Number")
        Else
            Set prop = doc.PropertySets("Design Tracking Properties")("Part Number")
        End If
        If doc.IsModifiable Then
            If prop.Value <> "" Then prop.Value = Split(prop.Value, ".")(0)
        End If
    Next
End Sub
Message 6 of 16
Hello there!
So far I haven't been able to find a tutorial or instructions on how to do a BOM modification and this thread is the closest thing I have found so far
Please see my picture:
Basically,2.PNG if we have 2 E-stops, BOM will list it as:
Main-Estop       AB          800T-FX6A5     qty            TAG1
Panel E-Stop    Blank      Blank                                  TAG2
And I basically want to do,
Main-Estop       AB          800T-FX6A5     qty            TAG1,TAG2,TAG3 ETC......
I can do it manually but it takes a lot of time
Any help or link will be totally appreciated
Thank you
Message 7 of 16
lihouxin065
I need to code by Inventor iLogic rules ,Would you do me a favor?
Message 8 of 16
A.Acheson
Use find and replace tool to remove the word "Set".
Create a sub routine called Sub Main and set up like this.
Sub Main
CleanWireBOM()
End Sub
Regards
Alan
Message 9 of 16
lihouxin065
Message 10 of 16
lihouxin065
Sub Main CleanWireBOM() End Sub Sub CleanWireBOM() Dim asmDoc As AssemblyDocument asmDoc = ThisApplication.ActiveDocument Dim oBom As BOM oBom = asmDoc.ComponentDefinition.BOM oBom.StructuredViewEnabled = True oBom.StructuredViewFirstLevelOnly = False Dim oBOMView As BOMView oBOMView = oBom.BOMViews(2) Dim compDef As ComponentDefinition Dim doc As Document Dim row As BOMRow Dim prop As Property For Each row In oBOMView.BOMRows compDef = row.ComponentDefinitions(1) doc = compDef.Document If compDef.Type = kVirtualComponentDefinitionObject Then prop = compDef.Propertys("Design Tracking Properties")("Part Number") Else prop = doc.Propertys("Design Tracking Properties")("Part Number") End If If doc.IsModifiable Then If prop.Value <> "" Then prop.Value = Split(prop.Value, ".")(0) End If Next End Sub
Message 11 of 16
A.Acheson
A few things when posting the code you can use the special editor to keep the formatting. See below.
So the property object needs a reference to Inventor so write it it in one of two ways
Inventor.Property
[Property]
In the find and replace of "Set" it unfortunately took it from "PropertySets" which is required.  The below code is functioning.
Sub Main
	CleanWireBOM()
End Sub
Sub CleanWireBOM()
	Dim oBom As BOM
	Dim doc As Document
	Dim row As BOMRow
	Dim prop As Inventor.Property
		Else
		End If
		End If
	Next
End Sub
Regards
Alan
Message 12 of 16
lihouxin065
Thank you very much for your reply, it looks like it only works for non-virtual parts, not for wires, cables, etc.
Message 13 of 16
A.Acheson
I think the issue is the nested sub assemblies of the structured BOM. There is no recursion on that rule so anything inside assemblies is ignored. You can use the parts only BOM and effect the parts.
Change this line from index of 2 to 3 or use the string "Parts Only"
oBOMView = oBom.BOMViews("Parts Only") 'index 2 is "Structured",'index 3 is "Parts Only"
Regards
Alan
Message 14 of 16
lihouxin065
Thank you for your patient guidance. After making some changes, it will also have an effect on virtual parts. The contents before the first "." from the left in the original part number are retained.
What should I do if I need to retain the content before the first "." from the right?
clear the contents enclosed by the blue curveclear the contents enclosed by the blue curve
Sub Main
	CleanWireBOM()
End Sub
Sub CleanWireBOM()
	Dim oBom As BOM
	oBom.PartsOnlyViewEnabled = True
	oBOMView = oBom.BOMViews(3) 'index 2 is "Structured",'index 3 is "Parts Only"
	Dim doc As Document
	Dim row As BOMRow
		Else
		End If
		End If
	Next
End Sub
Message 15 of 16
A.Acheson
You can remove the Split line and find the location of the right most deliminator then count from the left. Here is a sample. InStrRev function offical documentation
Dim TestText As String = "1234.456.789"
Dim RightDelim As Integer  = InStrRev(TestText, ".")
Dim Value As String = Left(TestText, RightDelim - 1)
 And here is how it will work in the rule. The only down side, if you run the rule twice you will remove more of the string. A work around could be to count the delimitators from the left if that is consistently 2x
     Dim ChangeText As String = prop.Value
     Dim RightDelim As Integer  = InStrRev(ChangeText, ".")
     If RightDelim > 0 Then
	     prop.Value = Left(ChangeText, RightDelim - 1)
     End If
   End If
End If
Regards
Alan
Message 16 of 16
lihouxin065
Thank you so much!
   The code can intercept the required characters as expected, but when dealing with the whole BOM, the wires, cables, and some virtual parts by length are merged and retaken in order, some lines are not processed after running the code.
How should I fix this problem.
before  running the codebefore running the code
after running the codeafter running the code
Sub Main
	CleanWireBOM()
	MessageBox.Show("Done", "CleanWireBOM")
End Sub
Sub CleanWireBOM()
	Dim oBom As BOM
	Dim doc As Document
	Dim row As BOMRow
		Else
		End If
		     End If
		   End If
		End If
	Next
End Sub
