Message 1 of 34
Hi.
I've used this Ilogic rule for years now.
But when i updated to inventor 2018 it wont work anymoore.
can anyone spot an error in this rule ?
See attached images for error message.
Thank you.
-Stian Sandhåland
SyntaxEditor Code Snippet
oPath = ThisDoc.Path oFileName = ThisDoc.FileName(False) 'without extension oRevNum = iProperties.Value("project", "revision number") oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oDocument = ThisApplication.ActiveDocument oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2'oOptions.Value("Custom_End_Sheet") = 4 End If 'get PDF target folder path oFolder = "k:\dwg\pdf\" 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If 'Set the PDF target file name oDataMedium.FileName = oFolder & "\" & oFileName & _ " rev" & oRevNum & ".pdf" 'Publish document oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) '------end of iLogic-------
