ilogic auto save pdf
sandhalet
Message 1 of 34
sandhalet
Hi.
I've used this Ilogic rule for years now.
But when i updated to inventor 2018 it wont work anymoore.
can anyone spot an error in this rule ?
See attached images for error message.
Thank you.
-Stian Sandhåland
SyntaxEditor Code Snippet
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("project", "revision number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2'oOptions.Value("Custom_End_Sheet") = 4
'get PDF target folder path
oFolder = "k:\dwg\pdf\"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
 'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & _
" rev" & oRevNum & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'------end of iLogic-------
Replies (33)
Message 21 of 34
per.widegren
Ohhh i´m so sorry 😞
Yes when Im ready with the drawing I want to save it and in the same time export an PDF and STEP.
It works briliant if you have an IAM only represented in the drawing.
If I have an IPN represented in the drawing it doesent work with the export of the step.
Hope this help  🙂
Message 22 of 34
bradeneuropeArthur
does the code work within a presentation file for you?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 23 of 34
per.widegren
Hello
No in the precentation file it´s not possible to open,edit or run Ilogic.
That tab turns in to "bank" when I´m in the Presentation mode. No options for adding those ilogic stuff....DRW3.PNG
Message 24 of 34
bradeneuropeArthur
strange behavior isn't it?
VBA works also here.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 25 of 34
per.widegren
it is indeed maybe it is an 2019 issue. I don´t really know 😞
Message 26 of 34
bradeneuropeArthur
shall we take a look then to do it with the Drawing?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 27 of 34
per.widegren
That would be really good. Sorry if I put you into the wrong track.
As I say. It works from the DRW if you have only a Part or an assy. If you have an presentation view then it cant export any stepfile. So some how we need to go in that case one step deeper and go for the assy that creates the presentation file.  Hope you follow me here.
Br
Per
Message 28 of 34
bradeneuropeArthur
That can happen between the other jobs...
I will take a look at it.
Dim oModelDoc As Document
Set oModelDoc = ThisApplication.ActiveDocument.ReferencedDocuments.Item(1).ReferencedDocuments.Item(1)
'MsgBox oModelDoc.FullDocumentName
Dim oSTEPTranslator As TranslatorAddIn
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext
Dim oOptions As NameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(oModelDoc, oContext, oOptions) Then
'Options for STEP output
oOptions.Value("ApplicationProtocolType") = 3 'Set application protocol: 2 = AP 203 - Configuration Controlled Design, 3 = AP 214 - Automotive Design
oOptions.Value("Author") = ThisApplication.GeneralOptions.UserName
oOptions.Value("Authorization") = ""
oOptions.Value("Tolerance") = "0.00001 mm"
oOptions.Value("Description") = iProperties.Value("Summary", "Title")
oOptions.Value("Organization") = "IKM Technique AS"
Dim oData As DataMedium
oData = ThisApplication.TransientObjects.CreateDataMedium
FilePath = ThisDoc.Path   'This .IDW's path
OutputPath = FilePath & "\" & "STP"    'Output destination for the new STP
OutputFileName = iProperties.Value("Project", "Part Number") '& "Rev" & oRevnum & ".stp" 'Output File Name as specified in Custom iProperties, as specified by the iLogic rule OutputFileName
'Check for existance of STP folder and create if not found
If Not System.IO.Directory.Exists(OutputPath) Then
    System.IO.Directory.CreateDirectory (OutputPath)
'Set the destination path & file name
oData.FileName = OutputPath & "\" & OutputFileName & "_Rev_" & oRevNum & ".stp"
'Publish Document
oSTEPTranslator.SaveCopyAs(oModelDoc, oContext, oOptions, oData)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 29 of 34
per.widegren
Hi Brad,
It seems to work now 🙂
Still i need to remove "set"
Many thanks for your help and quick responce 🙂
BR
Per Widegren
Message 30 of 34
per.widegren
Sorry 😞
Was a bit to quick here....
When having an assy drw then it works brilliant
when having a detail drw then I get this error....
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.DocumentsEnumerator.get_Item(Int32 Index)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Is possible to write the code so it works both on assy and detail drawings?
Br
Per
Message 31 of 34
I have used this rule as well.
It creates the pdf folder, as it is supposed to, but it is not save the PDF´s automatic?
I need to push the run rule, before it will save the pdf ?
I will like it to automatic save a new PDF, when i save the IDW?
Hope you can help.
Message 32 of 34
Jesper_S
Hi.
You could set an Event Trigger that fires the rule.
Before Save or After Save.
//Jesper
Message 33 of 34
Is it possible to make an ilogic code, which saves step files, like the one you have made to PDF - creating its one folder, for each project.
Like this one(only in a step file version)
If oPDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
oFolder = ThisDoc.Path & "\pdf" 'instead of "k:\dwg\pdf\"
'Publish document
Message 34 of 34
aronmatheus
I would like to create a ruler  to choose form the sheets separates, I had to utilize this code:
'['Sub Variables
oRefDocs = ThisApplication.ActiveDocument.AllReferencedDocuments
Dim oDoc As Document
oAddIns = ThisApplication.ApplicationAddIns
oTG = ThisApplication.TransientObjects']
'['PDF Export
'['PDF Options
PDFAddIn = oAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oContext = oTG.CreateTranslationContext
oOptions = oTG.CreateNameValueMap
oDataMedium = oTG.CreateDataMedium
'If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Vector_Resolution") = 4800
For Each oDoc In oRefDocs
idwPathName = Left(oDoc.FullDocumentName, Len(oDoc.FullDocumentName) -3) & "idw"
If System.IO.File.Exists(idwPathName) Then
oDrawDoc = ThisApplication.Documents.Open(idwPathName, True)
For Each oSheet As Sheet In oDrawDoc.Sheets
oSheet.Activate
oSheetName = oSheet.Name.Split(":")(0)
oDataMedium.FileName = oFolder & "\" & oSheetName & ".pdf"
Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium)
Next
Next']
MessageBox.Show("PDF Export completed.", "PDF Export", MessageBoxButtons.OK, MessageBoxIcon.Information, MessageBoxDefaultButton.Button1)
