ilogic auto save pdf
sandhalet
Message 1 of 34
sandhalet
Hi.
I've used this Ilogic rule for years now.
But when i updated to inventor 2018 it wont work anymoore.
can anyone spot an error in this rule ?
See attached images for error message.
Thank you.
-Stian Sandhåland
SyntaxEditor Code Snippet
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("project", "revision number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2'oOptions.Value("Custom_End_Sheet") = 4
End If
'get PDF target folder path
oFolder = "k:\dwg\pdf\"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
End If
 'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & _
" rev" & oRevNum & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'------end of iLogic-------
Replies (33)
Message 2 of 34
t_hascj
Hi sandhalet,
Similar issue was resolved in this discussion. https://forums.autodesk.com/t5/inventor-forum/pdf-ilogic/td-p/7409690
Try to add Dim to code.
Dim oContext As TranslationContext
Dim oOptions As NameValueMap
Dim oDataMedium As DataMedium
Jaroslav
Message 3 of 34
sandhalet
thx for reply
Tried adding dim to my code, but it didn't help.
but the code i found on the link works,
I was unable to change the save location however, it just saves the pdf in the same location as the idw file.
i tried to paste some of the code old code into the new code
But then the code does nothing.
i probably has to delete the part of the code saying to save the pdf at the idw location ?
-Stian
Message 4 of 34
t_hascj
Probably there is problem with duplicate "\"
oFolder = "k:\dwg\pdf"
Jaroslav
Message 5 of 34
MechMachineMan
Try this revised version.
If oPDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
End If
End If
'Publish document
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 6 of 34
sandhalet
Works perfectly.
Thanks 🙂
Message 7 of 34
mickmac06
Hi MechMachineMan,
I have copied your iLogic code that you very kindly posted on this forum, and I was wondering if you had a solution to save the PDFs into different folders? I want to save the PDFs into a dedicated PDF folder as shown in your iLogic, but your code creates a PDF folder, and all PDFs are saved into this one folder. I have a PDF folder created for each job, so depending on what job your are working on, the PDFs need to be saved to a PDF folder within the relevant job folder. Is this possible?
Mike
Message 8 of 34
bradeneuropeArthur
End If
oFolder = ThisDoc.Path & "\pdf" 'instead of "k:\dwg\pdf\"
End If
'Publish document
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 9 of 34
mickmac06
Thanks Bradeneurope, works a treat.
Mike
Message 10 of 34
bradeneuropeArthur
Your thanks are appreciated.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 34
per.widegren
interesting and very useful i must say. Many Many thanks for showing how the code can look like.
Is there any way to add creation of STEP file as well?
And how would that look like.
Sorry for all those questions but I´m really new on this.
BR
Per
Message 12 of 34
bradeneuropeArthur
Yes:
oStepAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
If oStepAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
' Set application protocol.
        ' 2 = AP 203 - Configuration Controlled Design
        ' 3 = AP 214 - Automotive Design
        oOptions.Value("ApplicationProtocolType") = 3
        ' Other options...
        'oOptions.Value("Author") = ""
        'oOptions.Value("Authorization") = ""
        'oOptions.Value("Description") = ""
        'oOptions.Value("Organization") = ""
End If
'get Step target folder path
oFolder = "k:\dwg\Step\"
End If
" rev" & oRevNum & ".stp"
'Publish document
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 34
per.widegren
Hello again,
I have now get it up and run and it works well.
This code create a step file and a PDF file as well when I´m in drawing mode. Works brilliant 🙂 BUT.......
When the drawing is showing exploded views it will not work No STEP file created just and PDF.
Is there any way to grab the source file (.IAM)from where the presentation mode (*.IPN) are build on?
This is how my code looks like right now.
'define the model referenced by the drawing
Dim oModelDoc = ThisDoc.ModelDocument
' Get the STEP translator Add-In.
Dim oSTEPTranslator As TranslatorAddIn
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
If oSTEPTranslator.HasSaveCopyAsOptions(oModelDoc, oContext, oOptions) Then
'Options for STEP output
oOptions.Value("ApplicationProtocolType") = 3 'Set application protocol: 2 = AP 203 - Configuration Controlled Design, 3 = AP 214 - Automotive Design
oOptions.Value("Author") = ThisApplication.GeneralOptions.UserName
oOptions.Value("Tolerance") = "0.00001 mm"
oOptions.Value("Description") = iProperties.Value("Summary", "Title")
oOptions.Value("Organization") = "IKM Technique AS"
Dim oData As DataMedium
oData = ThisApplication.TransientObjects.CreateDataMedium
FilePath= ThisDoc.Path    'This .IDW's path
OutputPath = FilePath & "\" & "STP"    'Output destination for the new STP
OutputFileName = iProperties.Value("Project", "Part Number") '& "Rev" & oRevnum & ".stp" 'Output File Name as specified in Custom iProperties, as specified by the iLogic rule OutputFileName
'Check for existance of STP folder and create if not found
If Not System.IO.Directory.Exists(OutputPath) Then
    System.IO.Directory.CreateDirectory(OutputPath)
End If
'Set the destination path & file name
oData.FileName = OutputPath & "\" & OutputFileName & "_Rev_" & oRevNum & ".stp"
'Publish Document
oSTEPTranslator.SaveCopyAs(oModelDoc, oContext, oOptions, oData)
End If
Message 14 of 34
bradeneuropeArthur
Dim a As Application
Set a = ThisApplication
Dim b As PresentationDocument
Set b = a.ActiveDocument
Dim oModelDoc = b.ReferencedDocuments.Item(1)'ThisDoc.ModelDocument
FilePath = ThisDoc.Path   'This .IDW's path
    System.IO.Directory.CreateDirectory (OutputPath)
End If
'Publish Document
End If
Or use this:
Dim oModelDoc = ThisDoc.ReferencedDocuments.Item
End If
'Publish Document
End If
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 34
per.widegren
Many thanks for the quick replay 🙂 Sorry to say but it´s not working,
I got this error in your second code
Rule Compile Errors in export4_step, in MEA00016.idw
Error on Line 1 : 'ReferencedDocuments' is not a member of 'Autodesk.iLogic.Interfaces.ICadDoc'.
and when I run your first code it gives me this error....
Rule Compile Errors in export5_step, in MEA00016.idw
Error on Line 2 : 'Let' and 'Set' assignment statements are no longer supported.
Error on Line 5 : 'Let' and 'Set' assignment statements are no longer supported.
The stucture looks like this...
It´s pretty much a standard setup i think...
IAM to IPN to DRW
Message 16 of 34
bradeneuropeArthur
The following:
Dim oModelDoc As Document
Set oModelDoc = a.Documents.Open(b.ReferencedDocuments.Item(1).FullDocumentName)
Put this in place.....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 34
per.widegren
Thank you for trying and your time you spend on this 🙂
Now it looks like this...
Message 18 of 34
bradeneuropeArthur
remove all "set" for ilogic
"set" is for VBA
 a = ThisApplication
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 19 of 34
per.widegren
hmm this wasn´t like "a walk thru the park" 🙂
Now it give me this back....
Error in rule: export5_step, in document: MEA00016.idw
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.PresentationDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D46C-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Message 20 of 34
bradeneuropeArthur
The code was intended to run from the ipn file not from the drawing.
Do you need it to be run from the drawing instead?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
