How to access part parameter in an assembly using VB.net
bwang-tecoustics
bwang-tecoustics
iLogic use:
Parameter("Part1:1", "d0")
But how to do this in VB.net? The part1 is in a assembly and I want to change a parameter in the part.
tolgay.hickiran
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-E2988B34-C0A9-49F8-993B-A9DB6EFD8EE9
here's the help document you need. This is also located in your Inventor aswell.
Some worthwhile ideas
Copy Design should rename ilogic Rules too!
Why Nastran In-CAD doesn't have an SDK?IMPLEMENTED!
Tolgay Hickiran
Founding Partner
SignatureSignature
website
emailskypelinkedinyoutubeemail
bwang-tecoustics
Thx. I was able to use the code below to access the UserParameter in the assembly. As the oOcc is the ComponentOccurence of the part, and its Parent is the assembly file. But what I'm trying to do is to change the value of the UserParameter in the part file, which is the oOcc itself.
oParas = oOcc.Parent.Parameters.UserParameters
The other question is the UserParameter.Value is an object per the help file. what should I do to change it's really value? Does Inventor treat the dimensions like "2 in" or "30 mm" as object?
bwang-tecoustics
Finally, I could use the following code to modify the UserParameters in the part file.
oOcc.Edit() 'Edit the part file in the assembly
                        Dim oPDoc As Inventor.Document
                        oPDoc = _invApp.ActiveEditDocument
                        Dim allParams As Parameters = oPDoc.ComponentDefinition.Parameters
                        oParas = allParams.UserParameters
oOcc.ExitEdit(ExitTypeEnum.kExitToParent) 'Exist editing after finish
MechMachineMan
If you already have the occurrence, the better method is this:
oUserParams = oOcc.Definition.Parameters.UserParameters
Editting the document first is cumbersome and much more resource intensive.
You can find this all in the API help....
%Public Documents%\Autodesk\Inventor 2017\Local Help\ad_mapi....chm
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
bwang-tecoustics
Thanks. This is better.
