Create workpoint from 3 planes
keithjk
Message 1 of 12
keithjk
I am trying to create a work point from 3 work planes that are created in the same sub routine.  The 3 work planes are create properly but I get an error when I try to create the work planes.
The following is a snippet from the code.  Everything works properly up to "wpNew = oAsmCompDef1.WorkPoints.AddByThreePlanes(oNewWorkPlane1, oNewWorkPlane2, oNewWorkPlane3)"
Also attached is the error message.
Any ideas?
'set up the work plane proxys
Dim oWorkPlaneProxy1 As WorkPlaneProxy = Nothing
oEnclosure.CreateGeometryProxy(oAssyPlane1, oWorkPlaneProxy1)
Dim oWorkPlaneProxy2 As WorkPlaneProxy = Nothing
oEnclosure.CreateGeometryProxy(oAssyPlane2, oWorkPlaneProxy2)
Dim oWorkPlaneProxy3 As WorkPlaneProxy = Nothing
oEnclosure.CreateGeometryProxy(oAssyPlane3, oWorkPlaneProxy3)
'these are the new assembly work planes
Dim oNewWorkPlane1 As WorkPlane = Nothing
Dim oNewWorkPlane2 As WorkPlane = Nothing
Dim oNewWorkPlane3 As WorkPlane = Nothing
Call oWorkPlaneProxy1.GetPosition(oOriginPnt, oXaxis, oYaxis)
oNewWorkPlane1 = oAsmCompDef1.WorkPlanes.AddFixed(oOriginPnt, oXaxis, oYaxis)
oNewWorkPlane1.Name = oNewWorkPlaneName1
Call oWorkPlaneProxy2.GetPosition(oOriginPnt, oXaxis, oYaxis)
oNewWorkPlane2 = oAsmCompDef1.WorkPlanes.AddFixed(oOriginPnt, oXaxis, oYaxis)
oNewWorkPlane2.Name = oNewWorkPlaneName2
Call oWorkPlaneProxy3.GetPosition(oOriginPnt, oXaxis, oYaxis)
oNewWorkPlane3 = oAsmCompDef1.WorkPlanes.AddFixed(oOriginPnt, oXaxis, oYaxis)
oNewWorkPlane3.Name = oNewWorkPlaneName3
Dim wpNew As WorkPoint
Replies (11)
Message 2 of 12
HermJan.Otterman
I tried to do it aswell, didn't work.
looked in the help, there it says:  This method is not currently supported when creating a workpoint within an assembly
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Message 3 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Keith,
In an Assembly, Workpoints can be created only using WorkpoInts.AddFixed method. Other methods are not supported. But using UI, WorkPoints can be created using "Intersection of Three Planes" as shown in the below image.
In a Part, Workpoints can be created easily using WorkPoints.AddByThreePlanes.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 4 of 12
keithjk
Herm Jan,
Thanks for the answer.
My work points do need to be placed at the intersection of three work planes.  Since addfixed seems to be the only way of adding them, do you have any  suggestions on how to get the intersection of the three work planes?
Keith
Message 5 of 12
keithjk
I figured it out....
I get the origin points of the 3 work planes and then determine the intersection of them by getting their x,y,z origin points.  I then use the workpoints.addfixed method.
Thanks for the help.  You got me pointed in the right direction.
Message 6 of 12
GeorgK
Hello keithjk,
is it possible that you post your code?
Thank you
Georg
Message 7 of 12
keithjk
Georg,
I got pulled away from this project but I did write some rough code to see if I could make it work. (So I know I should be able to clean it up when I get back to it).  The snippet below should give you an idea on how it works.
Dim oXaxis As UnitVector = Nothing
Dim oYaxis As UnitVector = Nothing
'these are the existing work planes
Dim oAssyPlane1 As WorkPlane = oOccDef1.WorkPlanes.Item("WP_Door")
Dim oAssyPlane2 As WorkPlane = oOccDef1.WorkPlanes.Item("WP_Left Side")
Dim oAssyPlane3 As WorkPlane = oOccDef1.WorkPlanes.Item("WP_Top")
'evaluate the 3 work planes
Dim oOriginPnt1 As Inventor.Point = Nothing
Call oWorkPlaneProxy1.GetPosition(oOriginPnt1, oXaxis, oYaxis)
Dim pt1 As Double = oOriginPnt1.Z
Dim oOriginPnt2 As Inventor.Point = Nothing
Call oWorkPlaneProxy2.GetPosition(oOriginPnt2, oXaxis, oYaxis)
Dim pt2 As Double = oOriginPnt2.X
Dim oOriginPnt3 As Inventor.Point = Nothing
Call oWorkPlaneProxy3.GetPosition(oOriginPnt3, oXaxis, oYaxis)
Dim pt3 As Double = oOriginPnt3.Y
Dim newPoint As Inventor.Point = oTG.CreatePoint(pt2, pt3, pt1)
Dim wpNew As WorkPoint = oAsmCompDef1.WorkPoints.AddFixed(newPoint)
Message 8 of 12
GeorgK
Hello keithjk,
thank you very much
Georg
Message 9 of 12
gkniksch
This thread was helpful. I didn't realize that "AddFixed" was the only method supported in Assemblies. Knowing that, I used that method to add a point arbitrarily in space, followed by constraining the new point to the three planes I was originally looking to use to add the point with. The three planes included two origin planes in the assembly and one workplane within another component. The component workplane required a workplaneproxy to access it.
I thought sharing this might be helpful to someone in the future. Cheers.
Set oWpt = oAssyDoc.ComponentDefinition.WorkPoints.AddFixed(oTg.CreatePoint(1, 1, 1))
oWpt.Grounded = False
Call oAssyDoc.ComponentDefinition.Constraints.AddMateConstraint(oWpt, oAssyYZ, "0")
Call oAssyDoc.ComponentDefinition.Constraints.AddMateConstraint(oWpt, oAssyXY, "0")
Call oAssyDoc.ComponentDefinition.Constraints.AddMateConstraint(oWpt, oPlaneFloorLengthProxy, "0")
Message 10 of 12
GeorgK
Thank you all for your help.
Georg
Message 11 of 12
llorden4
This appears to be a feature I've been long working on and needing.  I'm having a bit of trouble on the declarations, perhaps someone can assist...
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oAsmCompDef As ComponentDefinition = oDoc.ComponentDefinition
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oEnclosure As ComponentOccurrence     'I think this declaration is my issue but can't pinpoint which to use
Dim oAssyPlane1 As WorkPlane = oAsmCompDef.WorkPlanes.Item("Plane1")
Dim oAssyPlane2 As WorkPlane = oAsmCompDef.WorkPlanes.Item("Plane2")
Dim oAssyPlane3 As WorkPlane = oAsmCompDef.WorkPlanes.Item("Plane3")
Dim wpNew As WorkPoint = oAsmCompDef.WorkPoints.AddFixed(newPoint)
I'm currently getting this error:  Object variable or With block variable not set.
I making some educated guesses at some of the declarations you used in your post, clearly I'm not getting one or more correct.  Would appreciate the correction.
Autodesk Inventor Certified Professional
Message 12 of 12
llorden4
A bit more digging on this solution, there are more issues than just the declarations to overcome.  The code was developed for planes that exist in a part file and in a specific manner, so without those files to compare the current code against then this is not going to deliver a solution.
My personal goal is to find the intersection of three planes created within an assembly file, so the Proxy call isn't necessary.  I'm also wanting to handle any plane orientation that creates a single point of intersection for all three planes; so the steps used to create a point here are not useful.
If I manage a solution, I'll post it in this thread where I've created a post looking for that solution or idea to share with others.
