inventor parameter update delay
Message 1 of 9
hi all
I have 2 codes that show 2 values from a plane that intersects with an edge 1 plane is parallel to the orgine one other plane is under angel that changes.
now when i run my code the values of the intersection of the parallel plane to the origin is correct but the values of the plane thats under an angel are wrong it's like inventor doesn't update correct or something like that.
it shows for the plane under an angle 12.46 but it should be 12.31. seee my screen cast
here are my 2 codes
Code1:
SyntaxEditor Code Snippet
InventorVb.DocumentUpdate(True)
If Start = False Then Exit Sub
MessageBox.Show( X_Afstand_1_Cil, "Co�rdinaat X1")
MessageBox.Show( X_Afstand_2_Cil, "Co�rdinaat X2")
I1=Abs(X_Afstand_1_Cil)/((Binnen_diameter_cil/2)+Laagdikte_Cil)
J1=(Asin(I1)*180)/3.1415
M1=Abs(X_Afstand_2_Cil)/((Binnen_diameter_cil/2)+Laagdikte_Cil)
N1=(Asin(M1)*180)/3.1415
Q1=J1+N1
MessageBox.Show(Q1, "hoekt tussen X1 en X2")
Parameter("Start") = False
 Code 2
If Start_Y = False Then Exit Sub
MessageBox.Show(Y_Afstand_1_Cil, "Co�rdinaat Y1")
MessageBox.Show(Y_Afstand_2_Cil, "Co�rdinaat Y2")
Hoek_Alpha_cil=(afstand_tussen_de_trekken*360)/(Binnen_diameter_cil*3.1415)
MessageBox.Show(Abs(Hoek_Alpha_cil), "hoek booglengte")
Parameter("Start_Y") = False
Parameter("start_rules")=False
code 3 this code triggers the other 2
If start_rules= True  Then
Start_Y= True
Start= True
Replies (8)
Message 2 of 9
HermJan.Otterman
if you give a parameter a value than:
don't use:      Hoek = calculation
this will change the value at the end of the rule
but use          Parameter("Hoek") = calculation
(from the parameter snippets)
this will change the value directly
also put in the rule:
InventorVb.DocumentUpdate()
(from the Document snippets, Document update)
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Message 3 of 9
thanks for you're fast replie wil try it
Message 4 of 9
It doesn't help
this is my code now
Parameter("Hoek_Alpha_cil")=(afstand_tussen_de_trekken*360)/(Binnen_diameter_cil*3.1415)
Message 5 of 9
HermJan.Otterman
are the pieces of code in the same rule?
could you try to use the " Parameter("name") = calculation as well for the first code part?
if this is not helping, could you share your model? with the iLogic code.
it has something to do with the order in which things are done..
Herm Jan
Message 6 of 9
yeah i can share my part
to use the code you have to select the form keuze figuur and select cilinder
then you change afstand_tot_center_cil to a value you want
then you change afstand_tussen_de_trekken
then you put start_rules on true
 make sure that start and start_y are on false .
in attachement you will find my part.
Message 7 of 9
HermJan.Otterman
if you add a new rule at the end and put in only the two lines:
MessageBox.Show(Y_Afstand_1_Cil, "Coördinaat Y1")
MessageBox.Show(Y_Afstand_2_Cil, "Coördinaat Y2")
 then they will show you (twice) the correct values, so al other update have been done then.
so after rule code x richting cilinder the changes take place..
so for some reason the values are not calculated when you ask for them.
Herm Jan
Message 8 of 9
thanks would you know the reason why this problem occurs?
Message 9 of 9
HermJan.Otterman
it has to do with the order in which the calculations are done.
most of the values are changed at the end of a rule, when the rule is finished and not before.
I'm not shure where the point depend on but if they are related to the geometry, then that has to update first.
so it has to do with the order.
the last rule is a new rule, so all rules before that have finished, and the parameters than have the right values.
i cant find why the inbetween updates don't work.
Herm Jan
