On going balloon numbers
 I have two separate assemblies that are currently ballooned and finished. Each assembly starts with balloon number one in the stock list. My customer wants me make the balloon numbers ongoing over both the assemblies now. Is there a way to do this without over riding all the balloons on the second assembly manually?
The easy way would be to download https://apps.autodesk.com/INVNTOR/fr/Detail/Index?id=6329510225274883977&appLang=en&os=Win32_64
You can choose the number you want to start with and then you just have to click the balloons in the order you want the number.
Might have a way to do it using iLogic but I don't know.
bshbsh
in the model's structured parts list with the renumber button, you can set the starting number.
