ilogic loop
ilogic loop
ilogic loop
whats wrong with this code ? i want to let the code loop until distance is equal or greatet then 10.
SyntaxEditor Code Snippet
For distance <10
If start_rules= True  Then
Start_Y= True
Start= True
Next
HermJan.Otterman
use "While"   and   "End While"
while distance < 10  does an action as long as distance is smaler than 10.
watch out!! you can't stop this loop with the keyboard! only by killing Inventor CTRL ALT DEL, end process...
so before you use this : save! you code
or build in an escape that distance will become > 10 after 100 loops or so
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
