Exporting multi-sheet IDW to dxf (ilogic)
Darius_CAD
Message 1 of 22
Darius_CAD
I have already explored some of the posts regarding this subject.  But didn't find a solution.
Problem:   When I run rule (exporting multi-sheet IDW to DXF), DXF files have unnecessary first symbol "_" (please look at "1" .jpg).
I need:      That rule will check: if file name has this symbol "_" - delete (or skip this symbol), if file name not have it (when idw has one sheet), just leave file name.
My rule (exporting IDW to DXF):
' Get the DXF translator Add-In.
Dim DXFAddIn As TranslatorAddIn
DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options
If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
Dim strIniFile As String
strIniFile = "C:\CAD_2007.ini"
' Create the name-value that specifies the ini file to use.
oOptions.Value("Export_Acad_IniFile") = strIniFile
'Set the destination file name
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
'get DXF target folder path
oFolder = oPath & "\1.2_DXF"
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
 'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & "" &".dxf"
'long name
'oDataMedium.FileName = oFolder & "\" & oFileName &".dxf"
'oDataMedium.FileName = ThisDoc.PathAndFileName(False) & ".dxf" 'same folder, or uncomment:
'oDataMedium.FileName = "C:\myDXFfolder\" & ThisDoc.FileName(False) & ".dxf" 'fixed folder
'Publish document.
DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Any help would help out alot.... thanks!
Replies (21)
Message 2 of 22
bradeneuropeArthur
Add this to remove the _
Try
oFolder= oFolder.replace("_","")
Catch
end try
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 22
bradeneuropeArthur
Or better.
long name '
Try
oFilename.replace("_","")
Catch
End try
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 22
Darius_CAD
Thank you for your reply.
But it didn't help, but something wrong with my knowledge:)
Please look at again.
Try
oFilename.Replace("_","")
Catch
End Try
oDataMedium.FileName = oFolder & "\" & "" &".dxf"  ' Instead of "oFileName" I use this symbol "", because oFileName is IDW file name but I need just sheet name (2.jpg)
Message 5 of 22
bradeneuropeArthur
You need to define a fix filename!!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 22
Darius_CAD
Sorry, I don't understand. "You need to define a fix filename!!"  (I am knew in ilogic:(
I not need IDW file name, I just need IDW sheets names, but Inventor, when you saving multi-sheet IDW to dxf, add symbol "_".
Imposible save its without "_"?
Thank you for your time.
Message 7 of 22
bradeneuropeArthur
Where is your filename used. I cannot see that in your code.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 22
Darius_CAD
End Try oDataMedium.FileName = oFolder & "\" & "" &".dxf" ' Instead of "oFileName" I use this symbol "", because oFileName is IDW file name but I need just sheet name (2.jpg)
I not need IDW file name, so I just skip it. So I get good result: --> sheet name without IDW file name --> "_Sheet1" and "_Sheet2" ;So, after it, I have delete "_" manually.
If I save to dxf IDW (without ilogic rule), my result is:  FileName_Sheet1, FileName_Sheet2, ....
If I save to dxf with my rule, my result is :  _Sheet1, _Sheet2, ....
Maybe can use code, which delete FileName +1 symbol?  FileName_Sheet1    (Red symbols delete) ---> So result is       Sheet1, Sheet2,.....
Message 9 of 22
MechMachineMan
AFAIK, you have 2 options:
1. Change your code to only export 1 sheet at a time so you have full control over the file name and so it doesn't append sheet name. This would mean you would also have to change your code to cycle through each page and export each page individually.
2. Keep it the way it is, but use the FileSystemObject or System.IO functions to modify the filename AFTER it has been saved.
Good luck!
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 10 of 22
Darius_CAD
MechMachine,
Thank you for your advice, but it is uncomfortable, when you have ~50 multi-sheet for exporting to dxf.
Message 11 of 22
MechMachineMan
No, it's not "uncomfortable"!?
It's all handled in the programming. So change your code to suit 1 of those 2 options, and you'll be on your merry way with working code.
Justin K
Message 12 of 22
Darius_CAD
Sorry for my English, I will try, but my programming knowledge is basic:) I will try thank you.
Message 13 of 22
MechMachineMan
@Darius_CAD try the code below.
BUT FIRST, either export a new file with all sheets unchecked, or go to the ini and change the line "All Sheets = Yes" to "All Sheets = No".
Dim oDocument As DrawingDocument
oFolder = oPath & "\" & oFileName
End If Dim DXFAddIn As TranslatorAddIn DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'The below line might give issues depending on inventor version. Check forums if you are encountering issues. If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "C:\CAD_2007.ini" oOptions.Value("Export_Acad_IniFile") = strIniFile End If Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium Dim oSheetName As String For Each oSheet In oDocument.Sheets oSheetName = oSheet.Name oDataMedium.FileName = oFolder & "\" & oSheetName & ".dxf" DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) Next
Justin K
Message 14 of 22
Darius_CAD
Nice, file naming is working, but not converting to dxf. I got just files with 0 bites and not dxf (attached). Have you any ideas?
Message 15 of 22
MechMachineMan
2 things to try:
- If you just went into the ini file, try exporting a fresh one and using the code to change that.
- If that doesn't fix it, either add a message box to test that it is working, or just comment out the "HasSaveCopyAsOptions" line and try it again.
Justin K
Message 16 of 22
Darius_CAD
hm.. not working for me.
Message 17 of 22
MechMachineMan
Neither of those fixes did anything for you?
Justin K
Message 18 of 22
MechMachineMan
Ok... A couple tweaks were required.
1. It was not spitting out the proper sheet name and was not getting rid of the ":1" portion of the sheet name.
2. It was not activating each sheet.
Below has those issues fixed.
NOTE: Identical sheet names will just overwrite each other, so each sheet name must be unique.
	oSheet.Activate
    oSheetName = oSheet.Name.Split(":")(0)
	MsgBox(oDataMedium.FileName)
Next
Justin K
Message 19 of 22
Darius_CAD
Amaizing!
Best luck for you!
Thank you!
Message 20 of 22
aronmatheus
If I case have more 3 sheets, He prints 3 times? I observed the drawing staying misconfiguration!
