Exporting multi-sheet IDW to dxf (ilogic)
Darius_CAD
Message 1 of 22
Darius_CAD
I have already explored some of the posts regarding this subject.  But didn't find a solution.
Problem:   When I run rule (exporting multi-sheet IDW to DXF), DXF files have unnecessary first symbol "_" (please look at "1" .jpg).
I need:      That rule will check: if file name has this symbol "_" - delete (or skip this symbol), if file name not have it (when idw has one sheet), just leave file name.
My rule (exporting IDW to DXF):
' Get the DXF translator Add-In.
Dim DXFAddIn As TranslatorAddIn
DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options
If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
Dim strIniFile As String
strIniFile = "C:\CAD_2007.ini"
' Create the name-value that specifies the ini file to use.
oOptions.Value("Export_Acad_IniFile") = strIniFile
'Set the destination file name
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
'get DXF target folder path
oFolder = oPath & "\1.2_DXF"
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
 'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & "" &".dxf"
'long name
'oDataMedium.FileName = oFolder & "\" & oFileName &".dxf"
'oDataMedium.FileName = ThisDoc.PathAndFileName(False) & ".dxf" 'same folder, or uncomment:
'oDataMedium.FileName = "C:\myDXFfolder\" & ThisDoc.FileName(False) & ".dxf" 'fixed folder
'Publish document.
DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Any help would help out alot.... thanks!
Replies (21)
Message 21 of 22
Darius_CAD
Sheet names should be diferent. ?
Message 22 of 22
aronmatheus
Is there a way to export idw to dxf using logic to put all sheets in the same file dxf layout 1 and layout 2?
