Development: Looking for VBA example of an sidebar addin
Dear community,
could you give me a hint where to find an example to develop a sidebar for Inventor?
I already developed this one, which I would like to port to Inventor and would like to continue to develop together with you as a community project opensource'd. It might be that I'm using the wrong term ("sidebar"), therefore here a screenshot of what I have.
Thanks!
- Thomas
bradeneuropeArthur
Think you mean browser control!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
While browsing through the internet, it seems to be it. However, I only can find anything specific to begin to develop such a browser control.
Do you or someone else know, where to find a template or a good howto?
Many thanks so far!
bradeneuropeArthur
Try this way:
Sub DockableWindow()
    Dim oUserInterfaceMgr As UserInterfaceManager
    Set oUserInterfaceMgr = ThisApplication.UserInterfaceManager
    ' Create a new dockable window
    Dim oWindow As DockableWindow
    Set oWindow = oUserInterfaceMgr.DockableWindows.Add("SampleClientId", "TestWindowInternalName", "Test Window")
    ' Get the hwnd of the dialog to be added as a child
    ' CHANGE THIS VALUE!
    Dim hwnd As Long
    hwnd = 4851096
    ' Add the dialog as a child to the dockable window
    Call oWindow.AddChild(hwnd)
    ' Don't allow docking to top and bottom
    oWindow.DisabledDockingStates = kDockTop + kDockBottom
    ' Make the window visible
    oWindow.Visible = True
End Sub
Or look in the help file of inventor programming help file:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Thank you for the hint. I will take a look at it as soon as I have time.
When further questions occur, I will open new threads here in the forum.
Thanks!
