Transfering Sketched Symbols to new drawing
Message 1 of 24
I haven't done much programming at all in the last 10 years, so I am probably missing something simple here, but I don't understand why this is failing on the AddChild call
Any help appreciated.
Public Sub Test_SketchedSyms()
    Dim oDestinationdoc As DrawingDocument
    Set oDestinationdoc = ThisApplication.ActiveDocument
    Dim oSourceDoc As DrawingDocument
    Set oSourceDoc = ThisApplication.Documents.Open("C:\Test.idw", False)
    Dim oSketchSymNodes As ObjectCollection
    Set oSketchSymNodes = ThisApplication.TransientObjects.CreateObjectCollection
    Dim oSourcePane As BrowserPane
    Set oSourcePane = oSourceDoc.BrowserPanes.ActivePane
    Dim oDestinationPane As BrowserPane
    Set oDestinationPane = oDestinationdoc.BrowserPanes.ActivePane
    Dim oSourceSketchSyms As BrowserNode
    Set oSourceSketchSyms = oSourcePane.TopNode.BrowserNodes("Drawing Resources").BrowserNodes.Item("Sketch Symbols")
    Dim oDestinationSketchSyms As BrowserNode
    Set oDestinationSketchSyms = oDestinationPane.TopNode.BrowserNodes("Drawing Resources").BrowserNodes.Item("Sketch Symbols")
    Dim oBrowserNode As BrowserNode
    For Each oBrowserNode In oSourceSketchSyms.BrowserNodes
        Debug.Print oBrowserNode.FullPath
        oSketchSymNodes.Add oBrowserNode
    Next
    Dim oNode As BrowserNode
    For Each oNode In oSketchSymNodes
        oDestinationSketchSyms.AddChild oNode
    Next
End Sub
Replies (23)
Message 2 of 24
bradeneuropeArthur
What version of inventor do you use.
I understood that this is possible with inventor 2016 and up...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 24
Sorry I should have said, I use 2018.
Message 4 of 24
bradeneuropeArthur
You can already do that with the new library sketches!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 24
bradeneuropeArthur
If you need to know how. Please let me know.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 24
Thanks Bradeneurope,   I wasn't aware of the sketched symbol library.  Best I have been able to figure out so far is that the library entries don't show up in the browser, you have to access them via the insert sketch symbol dialog?  Everyone I know uses the browser 10x to the dialog box.  Is there a way to get them to show in the browser that I am missing?
Message 7 of 24
bradeneuropeArthur
Than import these from the library into your drawing!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 24
Thanks again, but I am not seeing anything about import for sketch libraries.  Can it be done through code, so it happens automatically?
Message 9 of 24
bradeneuropeArthur
You can add the sketches to the drawing. From the library
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 24
bradeneuropeArthur
But this can also by coding. I have this. But I am not at my desk right now. Asap
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 24
I talked to the person I am helping with this code, and they don't want to use the Library, mainly because it messes with the order of items.  So I am back to trying to figure out transferring from a template drawing.
Once again, I am missing something obvious I think.  I shrunk this down to the absolute minimum and it fails to create the folder.
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oPane As BrowserPane
    Set oPane = oDoc.BrowserPanes.ActivePane
    Dim oFolder As BrowserFolder
    Set oFolder = oPane.AddBrowserFolder("Test")
Message 12 of 24
bradeneuropeArthur
What are you trying to do with:
Think you need the drawing sketches!?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 24
bradeneuropeArthur
This should guide you in the right direction:
Public Sub dwgs()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim c As DrawingSketches
Dim d As DrawingSketches
MsgBox b.SketchedSymbolDefinitions.Count
b.SketchedSymbolDefinitions.Add (" SKETCH TO BE ADDED")
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 24
Thanks Brad, but the goal is to copy the sketched symbols folders and their sketched symbols in the same order from a template drawing to an open drawing.
The last code I posted is basically the Help Sample code converted from an assembly document to a drawing document and trying to just create a empty folder.
Message 15 of 24
What I am seeing is that the Browsernodes variant is required if the the file is a drawing when calling Addbrowserfolder.  If it is a part or assembly it isn't required. If I am correct in that, shouldn't it be documented in the  help file?
I don't yet have the code for what I want figured out, but at least I can quit trying to create a empty folder for a test.
Message 16 of 24
marcin_otręba
you always can copy sketchsymbols each by each:
Dim sketch_symbol As SketchedSymbolDefinition
For i = 1 To doc.SketchedSymbolDefinitions.Count
sketch_symbol = doc.SketchedSymbolDefinitions.Item(i)
sketch_symbol.CopyTo (targetdocument as DrawingDocument, replace existing as Boolean)
Next
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 17 of 24
bradeneuropeArthur
That's what I already tried to tell in my previous post too.......
Isn't that what you need?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 24
marcin_otręba
I only add that IT (copyto function) works with all drawing resources.. SO you can write your own drawingtransfer utility without aby limits like one folder at time
Ideas
or check my apps:
Message 19 of 24
Thanks for the replies, but unless I am missing something the copyto method doesn't bring folders.
The whole point is to bring the folder structure and sketched symbols from a template drawing to the current drawing in the same order (folders and sketched symbols ) as in the template drawing.
Now that I know I have to have browsernodes in the Addbrowserfolder call for my testing, I am to the point that I am adding a folder to the tree, but it ends up at the top of the tree instead of in the sketched symbols folder.
Message 20 of 24
marcin_otręba
Could you provide some screens form that folder structure?
Ideas
or check my apps:
