Assembly name restrictions in .addin file
spencer
spencer
Hit a bit of a snag with a custom add-in, long story short the .dll file now resides in a folder than includes a '&' character in the name. The Add In Manager really seem to not like this, and fails to load.
What kind of format is it even supposed to be in/can I get around this?
As it stands, the .addin is about like this
<Assembly>C:\Share Location\Thing & Stuff\etc\misc\Addin.dll</Assembly>
Tried several attempts of replacing the '&' with '&amp', '#0x36', and combinations of quotes but haven't gotten anywhere
bradeneuropeArthur
Special characters are not allowed. And also spaces not
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
spencer
The previous location (That did work without an issue) the Assembly tag was pointing to did have spaces and '()' characters though
chandra.shekar.g
Autodesk Support
Autodesk Support
@spencer,
Yes, "&" character is not recognizing in .addin file. But some other special character like "@" , "()",  Spaces are recognized. You can wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232/tab/most-recent
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
