iLogic edit
iLogic edit
iLogic edit
Hi everyone! I'm in the process of learning the utmost basics of iLogics and how to write rules. The person who previously did that at our company has left, and i've now been asked to modify some of his old rules. He had made a script to create a rev table, we now want to modify that rev table. After looking at the script i found where the parameters were set, and after trying to modify to add another column and change the name of an existing one it just won't work. There must be something I'm missing, and I dont know how fast i can learn to solve this problem. If any one could help me out by pointing out where i've overlooked something that would be fantastic. Thank you!
ORIGINAL SCRIPT:
SyntaxEditor Code Snippet
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
    'Look for partlist within drawing. End rule, if it doesn't exist.
    'say there is a Partslist on the sheet.
    Dim oRevisionTables As RevisionTables
    oRevisionTables = oSheet.RevisionTables
    If oRevisionTables.Count = 0 Then
        Dim oLocation As Point2d
        oLocation = ThisApplication.TransientGeometry.CreatePoint2d(6.667, 3.173)
        oRevisionTables.Add(oLocation)
           Dim oRevisionTable As RevisionTable = oRevisionTables.Item(1)
        If oRevisionTable.RevisionTableColumns.Count = 5 Then
        oRevisionTable.RevisionTableColumns.Item(1).Delete
           Dim oRevisionTableColumn As RevisionTableColumn
        Dim oColumnName As String
        Dim oWidth As Double
        Dim oContents As String
        For Each oRevisionTableColumn In oRevisionTable.RevisionTableColumns
        oColumnName = oRevisionTableColumn.Title
               If oColumnName = "REV" Then
               oWidth = .875
               oRevisionTableColumn.Width = oWidth
               If oColumnName = "DESCRIPTION" Then
               oWidth = 5
               If oColumnName = "DATE" Then
               oWidth = 2
               If oColumnName = "APPROVED" Then
               oWidth = 2
         Next
    'toggle parts list heading placement
          If oRevisionTable.HeadingPlacement = oRevisionTable.HeadingPlacement.kHeadingAtBottom Then
          oRevisionTable.HeadingPlacement = oRevisionTable.HeadingPlacement.kHeadingAtTop
          Else
      'toggle parts list direction
          If oRevisionTable.TableDirection = oRevisionTable.TableDirection.kBottomUpDirection Then
        oRevisionTable.TableDirection = oRevisionTable.TableDirection.kTopDownDirection
         Else
        Dim oRow As RevisionTableRow
        oRow = oRevisionTable.RevisionTableRows.Item(oRevisionTable.RevisionTableRows.Count)
        ' Make sure we have the active row
            If oRow.IsActiveRow Then
                Dim oCell1 As RevisionTableCell = oRow.Item(1)
                oCell1.Text = "0"
                Dim oCell2 As RevisionTableCell = oRow.Item(2)
    '                    'Set it equal to the user name on the open application
                oCell2.Text= "INITIAL RELEASE"
                Dim oCell3 As RevisionTableCell = oRow.Item(3)
                'Set it equal to the the current date
                oCell3.Text= "" 'DateTime.Now.ToString("d")
                Dim oCell4 As RevisionTableCell = oRow.Item(4)
                oCell4.Text= ""
MODIFIED (underligned where changed)
Dim oSheet As Sheet
        oLocation = ThisApplication.TransientGeometry.CreatePoint2d(6.367, 3.173)
               oWidth = .875
               oWidth = 5
               oWidth = 2
               If oColumnName = "DESIGN BY" Then
               oWidth = 2
               If oColumnName = "CHECK BY" Then
               oWidth = 2
         Next
          Else
         Else
                oCell1.Text = "0"
                oCell4.Text= ""
                Dim oCell5 As RevisionTableCell = oRow.Item(5)
                oCell5.Text= ""
MechMachineMan
1. The methodology used looks awful, and doesn't really follow the standard workflow of using styles to accomplish things. This system is wholly based on overrides.
2. Try this:
Dim oSheet As Sheet
 '       If oRevisionTable.RevisionTableColumns.Count = 5 Then
 '           oRevisionTable.RevisionTableColumns.Item(1).Delete
 '       End If
               'oColumnName = oRevisionTableColumn.Title
               Select Case oRevisionTableColumn.Title
                   Case "REV"
                       oWidth = .875
                   Case "DESCRIPTION"
                       oWidth = 5
                   Case "DATE"
                       oWidth = 2
                   Case "DESIGN BY" Then
                       oWidth = 2
                   Case "CHECK BY" Then
                       oWidth = 2
               End Select
         Next
          Else
         Else
                oCell1.Text = "0"
                oCell4.Text= ""
                oCell5.Text= ""
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
It produced the same issue we keep getting with the modifications that we've done too. No better. But thank you for taking a look. Knowing that it 'looks aweful' too helps to know that it could be done better. Like i had mentioned, this is all completely new to me and im not sure if it's 100% worth learning because it might just be simpler and more cost effective to have someone write the script for us.
MechMachineMan
Even with the lines commented out so that it's not deleting the first column?
I would check and see when you place the default revision block via the UI how many columns it has in and such.
Revising the styles would be the proper way to affect this change. It would then mean you could cut out about 85% of the code and accomplish the same thing.
Justin K
