iLogic: Determine radius of a cylindrical face
DRoam
Mentor Mentor
DRoam
Say I have a cylindrical face selected. How would I use iLogic to determine its radius?
I've been experimenting with this code:
ThisDoc.Document.SelectSet.Item(1).Evaluator.GetCurvatures()
But I can't figure out how the inputs work.
My end goal is to have my rule select all cylindrical faces under a certain radius. Right now I'm just trying to figure out how to determine a given face's radius in the first place.
JaneFan
Hi @DRoam
Radius of Cylindrical Face can be get in this way if you have select a cylindrical face in graphics window:
SyntaxEditor Code Snippet
MsgBox(ThisDoc.Document.SelectSet(1).Geometry.Radius)
If you want to select any face with a certain value, take part as example:
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
oDoc.SelectSet.Clear
Dim oFace As Face
For Each oFace In oDoc.ComponentDefinition.SurfaceBodies(1).Faces
	If oFace.SurfaceType = SurfaceTypeEnum.kCylinderSurface Then
		If oFace.Geometry.Radius = CertainRadiusValue Then
			oDoc.SelectSet.Select(oFace)
Next
Jane Fan
Inventor/Fusion QA Engineer
DRoam
Perfect, just what I needed. Thank you!
