Batch PDF Export from assembly not working
JoshuaNAM
Message 1 of 22
JoshuaNAM
Hi Inventor users,
I've copied several ilogic codes from different forums and edited them a bit to increase our productivity.when exporting to different file formats.
When using the rule to batch export a pdf from an inventor dwg we get the following error message:
Failed to publish DWF file
When running the rule from a standalone laptop (where the code was created) the illogic rule works correctly. When running the rule on a workstation and the rules saved on a sever the export fails.
We’ve reset the autodesk userprofile but that didn’t help.
We’ve reinstalled DWG trueview and Design Review but that didn’t make a diffenrence either.
Enclosed you’ll find the illogic code that we’re talking about.
Can anyone help me out?
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
oRevNum = iProperties.Value("Project", "Revision Number")
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
End If
'get user input
RUsure = MessageBox.Show ( _
"This will create a PDF file for all of the assembly components that have drawing (dwg) files." _
& vbLf & "This rule expects that the drawing file shares the same name and location as the component." _
& vbLf & " " _
& vbLf & "Are you sure you want to create PDF Drawings for all of the assembly components?" _
& vbLf & " " _
& vbLf & "This could take a while.", "iLogic  - Batch Output PDFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
End If
'- - - - - - - - - - - - -PDF setup - - - - - - - - - - - -
oPath = ThisDoc.Path
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 0
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
oOptions.Value("Custom_Begin_Sheet") = 1
oOptions.Value("Custom_End_Sheet") = 1
'get PDF target folder path
oFolder = oPath & "\" & oAsmName & "-Rev_" & oRevNum & "-PF" & "\" & oAsmName & "-Rev_" & oRevNum & "-PDF"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
End If
'- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the the drawing files for the referenced models'this expects that the model has a drawing of the same path and name
For Each oRefDoc In oRefDocs
dwgPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "dwg"
'check to see that the model has a drawing of the same path and name
If(System.IO.File.Exists(dwgPathName)) Then
                        Dim oDrawDoc As DrawingDocument
                oDrawDoc = ThisApplication.Documents.Open(dwgPathName, True)
            oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName) -3)
            On Error Resume Next ' if PDF exists and is open or read only, resume next
                 'Set the PDF target file name
                oDataMedium.FileName = oFolder & "\" & oFileName & "pdf"
                'Write out the PDF
                Call oPDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium)
            'close the file
                oDrawDoc.Close
Else
'If the model has no drawing of the same path and name - do nothing
End If
Next
'- - - - - - - - - - - - -Top Level Drawing - - - - - - - - - - - -
oAsmDrawing = ThisDoc.ChangeExtension(".dwg")
oAsmDrawingDoc = ThisApplication.Documents.Open(oAsmDrawing, True)
oAsmDrawingName = Left(oAsmDrawingDoc.DisplayName, Len(oAsmDrawingDoc.DisplayName) -3)
'write out the PDF for the Top Level Assembly Drawing file
oDataMedium.FileName = oFolder & "\" & oAsmDrawingName & "pdf"
'Write out the PDF
Call oPDFAddIn.SaveCopyAs(oAsmDrawingDoc, oContext, oOptions, oDataMedium)
'Close the top level drawing
oAsmDrawingDoc.Close
MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
'open the folder where the new ffiles are saved
Shell("explorer.exe " & oFolder,vbNormalFocus)
Replies (21)
Message 2 of 22
bradeneuropeArthur
Why are you dong this:
'Write out the PDF
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 22
JoshuaNAM
This last part is meant to open the dwg of the top level assembly where the code is being run from.
Message 4 of 22
bradeneuropeArthur
Why than change extension???
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 22
JoshuaNAM
What is a better way to open the dwg of the active assembly?
For retrieving the filename I've seen that this should be better...correct?:
ThisDoc.FileName(False) 'without extension
Message 6 of 22
bradeneuropeArthur
Where are the files saved/exported.
Maybe you have no rights to do that....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 22
JoshuaNAM
on the C-drive, shouldn't cause any problems.
Working with Vault Pro 2018 & INV Pro 2018.
Export location = vault folder on c-drive
iLogicrule location = on a network drive
Message 8 of 22
bradeneuropeArthur
of course this can be a problem.
Check this first...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 22
JoshuaNAM
Everyone has full rights to write on their C-drive. Do you mean the PDFAdInn might not have these writes?
If so how should that be organised?
Message 10 of 22
bradeneuropeArthur
So try this:
Put some messageboxes in your code like;
msgbox ("1")
msgbox ("2")
after each sub step in your code.
than take a look how far your code is working.
Plaese let me know what the resultm is...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 22
JoshuaNAM
The error occurs on this line:
                'Write out the PDF
                Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium)
Message 12 of 22
bradeneuropeArthur
on what part of the code
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 22
JoshuaNAM
See the line in red. I believe it's oContext that's giving the problem:
Exit Sub
End If
'get user input
& vbLf & " " _
& vbLf & " " _
Return
Else
End If
End If
                'Write out the PDF
            'close the file
                oDrawDoc.Close
Else
End If
Next
'Write out the PDF
Call PDFAddIn.SaveCopyAs(oAsmDrawingDoc, oContext, oOptions, oDataMedium)
Shell("explorer.exe " & oFolder, vbNormalFocus)
Message 14 of 22
MechMachineMan
@JoshuaNAM
With the original code, go back to the machine that it doesn't work on.
Go into your Windows settings and CHANGE the setting from "Hide known file extensions" to whatever it isn't currently. After doing that, go back and try to run the rule.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 15 of 22
bradeneuropeArthur
That is a good one....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 22
MechMachineMan
Please see my 'test section' of code below for notes, the fix, & some background.
I have confirmed it is the file extension setting & the lack of handling of that in the code.
oASMName = "ha"
oRevNum = "01"
End If
'oAsmDrawingDoc = ThisApplication.Documents.Open(oAsmDrawing, True)
oAsmDrawingDoc = ThisApplication.ActiveDocument
'NEW SECTION TO HANDLE ALL CASES
If RIGHT(oAsmDrawingDoc.FullFileName, 4) <> ".idw" Then
	oAsmDrawingName = oAsmDrawingDoc.DisplayName & "."
Else
End If
'END OF NEW SECTION TO HANDLE ALL CASES
 MsgBox(oAsmDrawingName & vbLf & oDataMedium.FileName)
 'if windows is set to hide file extensions, oAsmDrawing name becomes a shorted version of the display name
 'If it is set to show, it becomes the display name with a "." following it.
 'The common practice I have seen is to shorten the display name by 4 to remove the "." and then to change the oDataMedium.Filename to have ".pdf"
 'This isn't necessary. And it will still produce drawings of the wrong name if the file extension setting is not correct.
 'You could always modify the code to check whether or not it has a file extension and change the name accordingly before export to make the code work
 ' in all situations without having to change computer settings.
Justin K
Message 17 of 22
bradeneuropeArthur
This problem very of ten occurs. But is always forgotten. How often I saw that. But still always forgotten. Really good one.....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 22
bradeneuropeArthur
Tip.
You need to have good error handling in your code.
Implement that ASAP to prevent you for huge problems in future.
This is one of the disadvantages of copy and past.
You better try to reproduce the coding you are copying.
This is only meant as remark and a helping hand...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 19 of 22
JoshuaNAM
Hi MechMachine,
Thank you feedback! I've changed the windows settings of all the computers using Inventor and the code is up and running!
In the future I'll edit the code that it doesn't matter what the windows settings are. I gave it a try last night but due to time issues I'll have to pick it up another time.
Also thank you for the explanatory.
Kind regards,
Joshua
Message 20 of 22
JoshuaNAM
Hi Bradeneurope,
Thanks for your effort! You already pointed out a few things and helped me on my way. Learnt alot...thanks!
Kind regards,
Joshua
