Inventor Forum
Shaded with edges - edges outside model
6 REPLIES 6
daniel.puchta
765 Views, 6 Replies
I am having this issue - i use visual style "Shaded with edges". When I save my part/assembly, edges appear outside the model itself - like if I had different part in file with  visual style "Wireframe" - it is on the attached screenshot. When I change my camera view by zooming in/out and rotating, wrong edges disappear - but I am tired to do this everytime I save my part/assembly.
Is there any solution for this?
I am using Autodesk Inventor Profesional 2020 Build 239 64-bit version, my PC is Dell Precision 7530 with Windows 10.
Labels (2)
6 REPLIES 6
JDMather
in reply to: daniel.puchta
What graphics card do you have in that computer  (or is it Intel integrated graphics)?
daniel.puchta
in reply to: JDMather
Sorry I forget - It is NVIDIA Quadro P1000. I have also possibility to switch to Intel UHD Graphics 630 but I would rather not do that
What happens when you:
VIEW>>APPEARANCE>>REFINE APPEARANCE
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
JDMather
You might also try installing the latest Update for 2020.
daniel.puchta
I updated Inventor to version 2020.3 Build 373 and it helped. So it was problem with version 2020.1  Build 239.
Thank you a lot!
It was a problem with older version of Inventor. Anyway thanks for your reply
Technology Administrators
