I am having this issue - i use visual style "Shaded with edges". When I save my part/assembly, edges appear outside the model itself - like if I had different part in file with visual style "Wireframe" - it is on the attached screenshot. When I change my camera view by zooming in/out and rotating, wrong edges disappear - but I am tired to do this everytime I save my part/assembly.
Is there any solution for this?
I am using Autodesk Inventor Profesional 2020 Build 239 64-bit version, my PC is Dell Precision 7530 with Windows 10.
Solved by JDMather. Go to Solution.
What graphics card do you have in that computer (or is it Intel integrated graphics)?
Sorry I forget - It is NVIDIA Quadro P1000. I have also possibility to switch to Intel UHD Graphics 630 but I would rather not do that
What happens when you:
VIEW>>APPEARANCE>>REFINE APPEARANCE
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
You might also try installing the latest Update for 2020.
I updated Inventor to version 2020.3 Build 373 and it helped. So it was problem with version 2020.1 Build 239.
Thank you a lot!
It was a problem with older version of Inventor. Anyway thanks for your reply
