Inventor Forum
Extrude to Sketch Point?
6 REPLIES 6
mw2
814 Views, 6 Replies
I am a longtime Solidworks user who is considering switching to Inventor. My primary reason is that I am using AutoCAD more and more, and I am hoping that Inventor will even have slightly better integration with AutoCAD than Solidworks does. A few years ago I did a trial of Inventor and was frustrated by a few small things, one of which was I did not seem to have the ability, in Inventor, to extrude a feature and use a sketch point as the "extrude to" feature. In Solidworks I've developed the practice of using reference sketches for a lot of uses, one of which is to give extrusion points (I try to never reference vertices or faces etc, of actual features since they change most often as I revise designs).
Does the newest version of Inventor allow any such Extrude to a sketch point or similar?
Thank You
6 REPLIES 6
gcoombridge
in reply to: mw2
That approach is best practice in inventor too (in my opinion anyway).
You can definitely extrude to a sketch point, I do this many times a day.
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
Is there a way to extrude FROM a sketch point? If there is, I can't find it. It keeps asking me to "select face".
From SolidWorks, I also am used to having a skeleton sketch on a single plane and then extruding between vertices. Inventor seems to let me extrude TO a vertex but not FROM a vertex. Does this mean I'll have to create extra planes?
Hi Peter,
Indeed, Inventor does not support Extrusion starting from a point or a vertex or a workpoint. The starting selector has to be a face (planar or nonplanar) or a plane.
Many thanks!
Software Test Engineer
mw2
in reply to: peter.kapitola
Wow. I had no idea I could extrude in SW from a sketch point. Very cool to know....
johnsonshiue
in reply to: mw2
Hi! Fusion 360 also supports this workflow.
Many thanks!
Thanks. Digging further, it looks like this has been suggested a few times already. Hopefully it will get pushed through soon.
