I am a longtime Solidworks user who is considering switching to Inventor. My primary reason is that I am using AutoCAD more and more, and I am hoping that Inventor will even have slightly better integration with AutoCAD than Solidworks does. A few years ago I did a trial of Inventor and was frustrated by a few small things, one of which was I did not seem to have the ability, in Inventor, to extrude a feature and use a sketch point as the "extrude to" feature. In Solidworks I've developed the practice of using reference sketches for a lot of uses, one of which is to give extrusion points (I try to never reference vertices or faces etc, of actual features since they change most often as I revise designs).
Does the newest version of Inventor allow any such Extrude to a sketch point or similar?
Thank You
Thank You
Solved by gcoombridge. Go to Solution.
That approach is best practice in inventor too (in my opinion anyway).
You can definitely extrude to a sketch point, I do this many times a day.
Hi Peter,
Indeed, Inventor does not support Extrusion starting from a point or a vertex or a workpoint. The starting selector has to be a face (planar or nonplanar) or a plane.
Many thanks!
Hi Peter,
Many thanks!
Wow. I had no idea I could extrude in SW from a sketch point. Very cool to know....
Hi! Fusion 360 also supports this workflow.
Many thanks!
Many thanks!
