Inventor Forum
Inventor: Copy & Combine to make nests/intricate cuts
8 REPLIES 8
Message 1 of 9
baliasM74U3
379 Views, 8 Replies
Hi Experts
When I try to do as shown in link : https://www.youtube.com/watch?v=dvrMA15pj2o
I cant make 2 bodies in the copied body.
What am i doing wrong ?
Basil
8 REPLIES 8
Message 2 of 9
SharkDesign
in reply to: baliasM74U3
This is my video, I will just check for you.
  Expert Elite
  Inventor Certified Professional
Message 3 of 9
SharkDesign
Are you clicking the solid button in the copy command? This should automatically make two bodies.
Basic steps:
Two parts in an assembly.
Double click one.
Use copy object and click on the other
Select the solid option
Click OK (object is copied as a second body)
Click on return (blue arrow top right)
Open the part on it's own and there should be two bodies.
When you use the combine feature after to do a cut/combine it will become a single body again.
  Expert Elite
Message 4 of 9
baliasM74U3
in reply to: SharkDesign
Found it. Thanks for your video. its really helpfull.
Message 5 of 9
baliasM74U3
Message 6 of 9
baliasM74U3
Is this not available in INV 2018
Message 7 of 9
baliasM74U3
I tried doing this for a model for which I require a flat pattern (sheet metal part), but after combine cut & delet face is done, it is not letting me to make the flat pattern.
Message 8 of 9
SharkDesign
Are your rads and thickness Correct?
Attach your part if stuck.
See this video:
https://youtu.be/dAXE1iYkf5Y
  Expert Elite
Message 9 of 9
SharkDesign
It's definitely in 2018, did you try selecting body instead of face?
  Expert Elite
