I am a longtime Solidworks user who is considering switching to Inventor. My primary reason is that I am using AutoCAD more and more, and I am hoping that Inventor will even have slightly better integration with AutoCAD than Solidworks does. A few years ago I did a trial of Inventor and was frustrated by a few small things, one of which was I did not seem to have the ability, in Inventor, to extrude a feature and use a sketch point as the "extrude to" feature. In Solidworks I've developed the practice of using reference sketches for a lot of uses, one of which is to give extrusion points (I try to never reference vertices or faces etc, of actual features since they change most often as I revise designs).
Does the newest version of Inventor allow any such Extrude to a sketch point or similar?
Thank You
Solved by gcoombridge. Go to Solution.
That approach is best practice in inventor too (in my opinion anyway).
You can definitely extrude to a sketch point, I do this many times a day.
Hi Peter,
Indeed, Inventor does not support Extrusion starting from a point or a vertex or a workpoint. The starting selector has to be a face (planar or nonplanar) or a plane.
Many thanks!
Wow. I had no idea I could extrude in SW from a sketch point. Very cool to know....
Hi! Fusion 360 also supports this workflow.
Many thanks!
