Unable to Install Revit 2024 Error 4000
c_degennaro6ANS4
Observer Observer
c_degennaro6ANS4
Observer
Observer
I am unable to install revit 2024. It shows error 4000
I have tried to clean all the leftoovers from revit 2023, I have tried with reinstalling AdODIS but nothing works.
I have noticed that I can't get rid of AcSignCore16.dll, in the autodesk shared folder.
I have tried using Microsoft Program Install and Uninstall Troubleshooting
but it's unable to solve problems with revit 2023.
What could be the problem?
Simon_Weel
Have you seen this? Or this article? Looks like you didn't do much searching....
c_degennaro6ANS4
Observer
Observer
I did a lot of research.
I have already tried both solutions but they don't work. I still get the same error
pendean
Community Legend
Community Legend
This is an OS level issue: do you have n IT person (or repair shop) that can wipe your system clean and start over? A new log-in for you on the network (if you have that setup) would be advisable too.
TravisNave
Hold Shift and restart your computer.  That will give you the option to restart in safe mode with networking.  Do so.  When you log back in, you should be able to clear out all of the files that are locked from deletion.  Then reboot normally and see if you are still getting errors.  Post your new results back here.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
c_degennaro6ANS4
Observer
Observer
Before reading your suggestion I have deleted anything related to autodesk with Microsoft Program Install and Uninstall Troubleshooting,  apparently it could read something related to all the old versions of autodesk products ( leftovers from revit 2023 couldn't be removed though). I tried reinstalling again 2024 and it worked. Now i  can't open files from previous version of revit, it says they are all damaged, don't know if it's still related to some installing issues. I need to reinstall revit 2023 and i am quite scared it could cause me problems again 🤕
