Hello @Anonymous,
Thanks for posting, the Windows 10 operating system you are running can not support the product. Please take a look at the system requirements,
unsupported products can work in some cases but this operating system is a lot newer and is unlikely to function with such an outdated product.
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
autocad 2013 got installed in another windows 10 pc without any issue
AutoCAD 2013 is definitely not supported on Windows 10. But if the installer is having a problem with the temp file location, then change the user environment variable of %TEMP% and %TMP% to a local folder instead, like C:\TEMP for example. Then reinstall with UAC off and Run as Administrator. Also temporarily disable you realtime anti-virus scanner.
Good Luck!
