Revit 2016 displaying problem
526996629
Message 1 of 13
526996629
Hi
i successfully installed revit 2016 on my 3k resolution thinkpad w540. The display adapters of my computer are Inter(R) HD Graphics 4600 and NVIDIA Quadro K2100M.
The problems is:
In picture A, "1" is not showing currectly which is dark unless when I move my mouse to it. "2" keeps twinkling all the time. I haven't seen it remain stable for now. When I open a revit file, changing to the floor plan, nothing showed up.
When I minimize Revit, and then maximize it again, the floor plan showed up, but the toolbar became black again. (showed in Picture B)
I have tried all recent versions of Revit, but all turned up like this. All my other Autodesk software work well. (I used vasari before,same problem. I think it's because it was still based on the platform of Revit.)
I'm not sure if it is related to any vedio card of my computer or screen resolution, or any other plugins or drivers.
This is really confusing me.  Hope some one can help me.
Replies (12)
Message 2 of 13
Otto
Hello 526996629
It looks like you are having Revit installation issues. Community members with similar questions found the following article(s) useful:
For issues with Revit Server, please see the System Requirements for Revit Server.
If you are installing on Windows 10, please check that your product is compatible.
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 13
526996629
Sorry, not really helped. Detail solutions needed. Thanks
Message 4 of 13
TravisNave
Perform a clean install of the latest WHQL certified driver for your video card:
http://www.nvidia.com/download/driverResults.aspx/96383/en-us
Then make sure that you are using the Quadro card for Revit and that your laptop doesn't use the built-in Intel card.  Sometimes you can do this within your settings or your BIOS.  Somtimes it's called Optimus in the BIOS.  Sometimes there is a hard button on the keyboard.  You will have to look that up, likely.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 5 of 13
526996629
Thanks for your help, but it seems the problem is not solved.
My system is win 10, and I followed the website you provided and found the one compatible for win10. And I checked that Revit was using the NVIDIA processor.
Unfortunately, almost nothing changed in Revit. What changed as I considered is the frequency of the twinkling at the bottom(Picture A :number "2") which is getting a bit slower.
Message 6 of 13
TravisNave
Windows 10 is not supported, so you might have to live with this issue for awhile unfortunately.  You could also see if changing it to use the Intel card helps.  It might.
Autodesk Forums:
Message 7 of 13
526996629
Do you mean this solution not suitable for win10?  Because I found the compatible driver for win 10 on that website.
If not support win10, do you know what is the reason why this problem happens?
Revit works well on my friend's different computers and they are also using win 10. I'm really confused why it does not work well on mine. When I was using win 8, this problem also happened. And I thought win10 might help solving the problem but it let me down.
Message 8 of 13
TravisNave
I'm just noting that Windows 10 is not a supported OS for your product.
The issue, and difference between your computer and your friends' computers, is likely your video card.  Since the problem did not get fixed from Windows 8.x to 10 nor from an updated driver, then it is likely a hardware limitation of the card itself.
Autodesk Forums:
Message 9 of 13
526996629
This computer was bought less than 1 year ago. And is a thinkpad workstation. I do agree there might be some hardware limitation. But I am really confused why older versions of revit also didn't work well.  I do wonder what the limitation is with this computer. As a thinkpad workstation, it is supposed to be good for autodesk software.(It really works nice with other autodesk software.)  This is really confusing. Althought problem not solved, thanks for your help.
Message 10 of 13
TravisNave
I can definitely see your point of view.  I did check the Autodesk approved hardware list and your card is not on it.  The K2200M is, however.
http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534&results=1&stype=graphic&produ...
Autodesk Forums:
Message 11 of 13
526996629
Ya,seems so. Does this mean my current computer will never be able to use Revit successfully? Do I have any other choices apart from changing a new computer?
Message 12 of 13
526996629
I just tried Revit 2014. NVIDIA Quadro K2100M is in its list. But same problem happened. It seems there should be some other reasons.
By the way, the list is for recommendation. So some not on that list still has the potential to work the software successfully.
After the test on Revit 2014, I do consider there be other reasons. Below is some information of the computer in case it helps.
Pointing device                                          W540 FPR 5BCP w/NFC w/CS
WiFi wireless LAN adapters                        Intel 7260 BT ACBGN
Wireless WAN accessories                         MBL BB upgradable, future use
RAID Setting                                             Internal RAID - Not Enabled
Color Sensor                                             Color Sensor
System Unit                                              W540 NVIDIA Quadro K2100M 2GB
Storage Adapter                                        No M.2
Security Chip 2                                          Security Chip Enabled
Display Panel                                             W540 15.5 3K IPS WWAN CS
Processor                                                  Intel Core i7-4910MQ
Message 13 of 13
TravisNave
Normally I would recommend trying the driver that they list on that Autodesk supported site.  But since it is likely for Windows 7 instead of Windows 10, it may not work for you.
You might also try logging in as another user on that computer and launch Revit to see if the problem is specific to your computer or to your Windows profile.
Autodesk Forums:
