opt file using wildcard
Message 1 of 11
If got a question regarding wildcards in opt-files (adskflex.opt).
I found some websites telling that wildcards are possible for subnet IP like 192.168.0.* but is this also working for computer names e.g. PC12* ?
Does anyone have experience using wildcards in opt-files?
Best regards,
Rene
Replies (10)
Message 2 of 11
Mark.Lancaster
ReneHoefer
Its been a while but I'm thinking the wild card is only possible on IP Address..  But not 100% sure..  I'm tagging @Darin.Green and @TravisNave who have more experience with option files...  Hopefully they can give you a solid answer.
Mark Lancaster
Message 3 of 11
TravisNave
Unfortunately no. Wildcards only work for the IP address. I can understand the pain of having to add a bunch of items to a group. But you can probably export your computer list from the AD server and just copy all of the PC12* you need that way. That's what I'd do.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 4 of 11
Darin.Green
@Anonymous Welcome to the community!
A better solution would be to use the LM_PROJECT system variable also known as project association. Use the following link as a guide for implimenting:
Defining Project Association
With this solution, you'll only need to create the LM_PROJECT system variable and provide a name for this project. Once this is done on everyone's machine, you need to add the following to your Options file:
Example:
GROUPCASEINSENSITIVE ON
RESERVE 5 85788BDSADV_F:SIGN=SIGN="0CC2 E5D3 B44B 325D 9045 \
769B 7529 7D1C E2E5 96D6 3061 F6FC 5BFD FFAA BB60 058D 9A4E \
A235 EC00 599C 154F 15E1 3D35 B806 836C 008E 9F8B E0F7 CAF3 \
6165" PROJECT ProjectValue
If this information was helpful, please consider using the Accept Solution
Message 5 of 11
Thank you all for your sugestions and fast responses.
Cheers,
Rene
Message 6 of 11
rkmcswain
Hey @TravisNave - so to confirm, if you were doing something like setting the MAX_BORROW_HOURS, you'd need a separate line for each product code....
MAX_BORROW_HOURS 87224ACD_2020_0F 336
MAX_BORROW_HOURS 87084ACD_2019_0F 336
MAX_BORROW_HOURS 86830ACD_2018_0F 336
and so on?
MAX_BORROW_HOURS * 336
Will not work, right?
R.K. McSwain     | CADpanacea | on twitter
Message 7 of 11
TravisNave
Correct.  The options file will not recognize a wildcard for this -- it has to be a matching feature code.  And if there are duplicate values for the same feature, the last one will supersede the others.  Once implemented and reread in, the debug log file should verify that the option has been activated.
Autodesk Forums:
Message 8 of 11
rkmcswain
Thanks @TravisNave - 18 more months and we won't have to worry about all this madness any longer! LMTOOLS has been such a hassle for the past 3 decades....
<sarcasm off>
Message 9 of 11
TravisNave
Hahaha!  I am such an expert in it though, what am I supposed to do now?  😅
Autodesk Forums:
Message 10 of 11
rkmcswain
Doesn't ESRI and several others still use it?
Message 11 of 11
TravisNave
Yes, many other clients still do. So I guess I will be fine.
Autodesk Forums:
