Announcements
How to change REVIT LT2017 License Number
pendean
Community Legend
pendean
Community Legend
Community Legend
Trying to change a license number for a seat of REVIT LT2017 and it basically just won't let me, it keeps finding and reusing the old/previous seat. Any tips?
I even had the user try a removal/reinstall of the software and purge of all Autodesk folders and it still comes back with the old serial number.
Win7Pro is the PC's OS.
Replies (9)
Darin.Green
This should help get your application working. Assuming you have a valid serial number/contract.
  1. On your computer, navigate to:
    • ​​C:\ProgramData\Autodesk\CLM\LGS\<product key>_<<product version>>\
  2. Delete the LGS.data file.
  3. Navigate to
    • C:\Users\<username>\AppData\Roaming\Autodesk\
  4. Delete the ADUT folder and it's contents
  5. Start the application.
If this information was helpful, please consider using the Accept Solution
pendean
Community Legend
Community Legend
Sadly that did not work @Darin.Green: it still found the old serial number from somewhere.
Any other ideas?
TravisNave
Dean,
You might try renaming the adsk*.data files in C:\ProgramData\FLEXnet.  And if that doesn't work for some reason, then you might have to rename the ProductInformation.PIT file in C:\ProgramData\Adlm, but that would also kill the rest of the installed products on your machine.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
natasha.l
Hello @pendean,
Sorry about that, have you tried signing in and updating the serial number from the License Manager screen. You may find the solution in this link if my suggestion doesn't workout. Hope this helps! Smiley Happy
Update Serial Number
Thank you.
pendean
Community Legend
Community Legend
That only applies to AutoCAD, not REVIT/LT: you need to update the incorrect info/links for programs other than AutoCAD.
The kind-of similar process in REVIT/LT (from the top-right most log-in pulldown) puts the program in Viewer Mode only and any option to "enter serial number" seems to find the old number and not offer any opportunity to enter a new one.
I have not idea how or where it keeps finding the old serial number and skip allowing me to enter a new serial number.
natasha.l
Hello @pendean,
Sorry about that, I have included a screenshot of my Revit LT 2016 should be very similar. Let me know if it works. Smiley Happy
Darin.Green
@pendean - Sorry for not responding sooner... Company holiday party...
Revit has a license config file located C:\Programdata\Autodesk\RVT 2017. I forget the folder name for Revit LT, but it should be similar. Once in the folder, there should be a file called LicConfig.ini, open it with Notepad and change the SerialNumber value to the correct serial number.
That should be all you need to do. Keep me posted.
pendean
Community Legend
Community Legend
Thanks @natasha.l and @Anonymous, I just went ahead, reimaged the drive, and moved on with my day. Problem solved 🙂
Darin.Green
Sometimes that's the fastest way, especially during critical times...Smiley Wink
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
