& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
I am using design automation with AutoCAD. But I got an error that looks like "timeout" I don't know what the problem is and how to fix it. Help me, please. Thanks so much. This is the report of design automation.
[03/10/2023 09:52:07] Start script phase.
[03/10/2023 09:52:07] Start AutoCAD Core Engine standard output dump.
[03/10/2023 09:52:07] Redirect stdout (file: T:\Aces\Jobs\8ab2b9c2e8c04c6f9e6401a760efc4c3\tmp\accc28282). [03/10/2023 09:52:07] AcCoreConsole: StdOutConsoleMode: processed-output: disabled,auto
[03/10/2023 09:52:07] AutoCAD Core Engine Console - Copyright 2021 Autodesk, Inc. All rights reserved. (S.51.Z.120) [03/10/2023 09:52:07] Execution Path:
[03/10/2023 09:52:07] T:\Aces\AcesRoot\24.1\coreEngine\Exe\accoreconsole.exe [03/10/2023 09:52:07] Current Directory: T:\Aces\Jobs\8ab2b9c2e8c04c6f9e6401a760efc4c3
[03/10/2023 09:52:07] Isolating to regkey=HKEY_CURRENT_USER\SOFTWARE\AppDataLow\Software\Autodesk\CoreUser\WorkItem_8ab2b9c2e8c04c6f9e6401a760efc4c3,userDataFolder=T:\Aces\Jobs\8ab2b9c2e8c04c6f9e6401a760efc4c3\userdata.
[03/10/2023 09:52:07] Version Number: S.51.Z.120 (UNICODE)
[03/10/2023 09:52:07] LogFilePath has been set to the working folder.
[03/10/2023 09:52:08] Regenerating model.
[03/10/2023 09:52:08] AutoCAD menu utilities loaded.
[03/10/2023 09:52:08] Command:
[03/10/2023 09:52:08] Command: DETECTIONCMD
[03/10/2023 09:53:08] Error: AutoCAD Core Console is shutdown due to timeout.
[03/10/2023 09:53:08] End script phase.
[03/10/2023 09:53:08] Error: An unexpected error happened during phase CoreEngineExecution of job.
[03/10/2023 09:53:08] Job finished with result FailedExecution
It looks like your DETECTIONCMD doesn't have anything to do and then times out. Do you have anything scripted to run a command? You might double-check.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
