Extracted files 4 CADMEP 2016 wont copy from none evident folder structure
ukdxb012
Advisor Advisor
ukdxb012
I'm trying to create a Deployment Image for FAB CAD MEP 2016, i've downloadewd via browser download, extracted the package, deleted the autorun.inf and commenced with creating the DI, unfortunately it wont let me create this as it cannot copy files from the extraction to the server, however the files/folders it's looking for dont exist in the DI.
The copy functions cannot be used.
Failed to copy the following files:
C:\Autodesk\Autodesk_Fabrication_cadmep_2016_Engli​sh_64bit_dlm\NLM & C:\Autodesk\Autodesk_Fabrication_cadmep_2016_Engli​sh_64bit_dlm\ADAPPLICATIONMANAGER & C:\Autodesk\Autodesk_Fabrication_cadmep_2016_Engli​sh_64bit_dlm\BIM360GLUEFABRICATIONADDIN
Is this a bug or an issue specific to my work's environment? Has anybody else tried installing FAB CAD MEP 2016 yet?
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
TravisNave
Interesting issue.  Can you manually copy the files?  I didn't know if there was some sort of CRC issue with the files causing them to be bad or something.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
ukdxb012
Very strange to say the least!
I can create the folder it's looking for from the extraction which allows me to progress with the install a little further but then i get the same issue with another folder. Having to stop and start the deployment process to understand whats needed to create a Deployment Image is not something i'm prepared to do so gave up after 3 attempts.
It installed fine manually!
The first attempt it gave me this... C:\Autodesk\Autodesk_Fabrication_cadmep_2016_Engli​​sh_64bit_dlm\NLM so i created NLM and redid the DI, then it gave me this... C:\Autodesk\Autodesk_Fabrication_cadmep_2016_Engli​​sh_64bit_dlm\ADAPPLICATIONMANAGER so i created ADAPPLICATIONMANAGER and redid the DI, then it gave me this... C:\Autodesk\Autodesk_Fabrication_cadmep_2016_Engli​​sh_64bit_dlm\BIM360GLUEFABRICATIONADDIN
If i new what was needed manually to exist in the extraction folder, i would create them all to simply create a DI. Looks like it has been packaged wrongly.
Duncan Brannan
Twitter | LinkedIn
