Autodesk Mudbox
Autodesk Mudbox
Autodesk Mudbox
I had recently downloaded Autodesk Mudbox 2014 student version. but I am not able to install it it show sthe following error:
Error 1308 Source file not found:  C:\ Autodesk\wi\Autodesk Mudbox2014\x64\Mudbox\ProgramFiles\Autodesk\Mudbox2014\UPICA.dll.
Verify that this file exists and that you can access it.
What should I do for this? How do I install it?
Thanks for your help
SM
Otto
Hello sashikala66 and welcome to the Autodesk community!
It looks like you are seeing a Windows Installer Error Message. The following article(s) should help you resolve the problem:
Windows Installer Error Messages
Errors during AutoCAD software installation
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
TravisNave
Get a full download and always make sure to install with local admin rights, UAC disabled, and anti-virus temporarily turned off.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Sir/Madam
I tried installing through the Virtual agent as per your message below.
But the file is not downloading
Rgds
SM
.com/customer-service/account-management/software-downloads/download-methods/virtual-agent
TravisNave
How do you mean it isn't downloading?
Autodesk Forums:
