Autodesk CFD Install Problem
maxschommer
maxschommer
I was installing Autodesk CFD and everything was working fine, then it got to around half way through and failed to make any more progress. I figured it didn't take long to get to where it was, so I would cancle the installation and reinstall. When I try to uninstall what had been installed, it says "uninstall failed" and the non-working program is stuck on my computer.
Otto
Hello maxschommer and welcome to the Autodesk community!
It looks like you need to find out more about downloading or re-downloading software, or are having issues that may be resolved by re-downloading.
For Windows users, before downloading products on Windows 10, please check that the product is compatible.
For general information about downloading or re-downloading (including eligibility), Community members with similar questions found the following article(s) useful:
Download Finder
Previous Versions of Autodesk Software
Download Methods
Find Your Eligibility for Previous Versions of Autodesk Software
Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. Community members with similar issues found the following article(s) useful:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
TravisNave
Cancelling was your biggest mistake.  It was not stuck, it was simply downloading additional install files that were multiple gigabytes in size.  Depending on your connection speed, it could possibly take a few hours.  Patience would have gotten you installed.  Now you have a serious issue.
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://knowledge.autodesk.com/customer-service/installation-activation-licensing/get-ready/remove-pr...
Good Luck
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
maxschommer
I did a clean uninstall and wiped cfd from all of my files. This seemed to work, because I was able to install it in 10 minutes afterwards. I think the original problem was that during the install I switched from wifi to ethernet and the installer didn't know what to do. Thanks for all of your help,
Max Schommer
maxschommer
Thanks for your reply, it was a much more focused solution than the above general "try all of this" solution and it ended up working. Thanks,
Max Schommer
luca.letroye
Observer
Observer
i've done that but now when my solving is done it gives an error and says my solves has stopped
