Autodesk Access Core
CivilNJ
CivilNJ
I don't want my users getting notifications about new releases, patches, etc.  Why would that be useful to an admin?  They aren't able to install anyway, so it just makes admin job a chore.
https://forums.autodesk.com/t5/autodesk-access-forum/updating-your-autodesk-tools-what-to-know-about...
I want to turn off ALL access to users other than identity and licensing requirements.
TravisNave
As an IT Admin myself, I agree.  I believe you can go into Task Manager > Startup and disable the automatic startup for the AdskAccessCore.exe process.  That should prevent it from starting up and causing you headaches.
The file itself lives in the following location if you want to tank it altogether:
C:\Program Files\Autodesk\AdODIS\V1\Setup
Hope that points you in the right direction.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
mdavis22569
Have you seen the FAQ
https://help.autodesk.com/view/ACCESS/ENU/?guid=GUID-2533F9BE-4929-433D-93DE-D330CC6BA3A6
How is Autodesk Access different from the Autodesk desktop app?
Access is built using the latest Autodesk installation technology, providing the faster install experience. The first version of Access focuses on product updates. Access serves as a platform for exciting future capabilities that will make the update experience even better. Here are some of the differences found in the current release of Access:
  • Access provides admin controls to disable their users' ability to install updates.
  • Access includes new update notifications.
  • Access doesn't yet include settings for a local download cache or options for installing from a shared network location.
  • With Access, users are redirected to Autodesk Account for full product installs.
Mike Davis
mdavis22569
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Disable-updates-In...
https://www.autodesk.com/products/autodesk-access/overview
Mike Davis
CivilNJ
Restart and it is back.
Anyway, I will have to use the registry hack to indicate that installs are admin controlled but this is nuts.
Thanks!
-Jim
CivilNJ
Thanks!
-Jim
TravisNave
When I disable a file and it comes back, it is affectionately known as a virus.  🤣
Autodesk Forums:
