Win7Pro
Network and Local Admin rights with log-in
AutoCAD and LT 2018 installation files downloaded before the installation started.
AutoCAD 2018 installed just fine. No issues.
Restarted WIndows.
Logged in, Authorized it. works fine.
started AutoCAD LT 2018 installation. It refuses to complete installation, gets stuck at language packs. Log-file attached.
Tried "RUN AS ADMINISTRATOR" as well as logging in as a new user with admin rights, tried all the error1603 and error 1619 tips to no avail, same problem persists.
What am I missing? I plan on ignoring Otto by the way.
I don't want to sound negative or being the first time I disagreed with you...
But I thought language packs can only be installed after the core product is installed... Meaning the logs shows Acad LT installation being rolled back..
Mark Lancaster
& Autodesk Services MarketPlace Provider
Correct, Mark. So there's two ways to go about this:
1. Modify the setup.ini to ignore the Language Pack failure and hope it works to prevent the rollback
#============================= ACAD LT Language Pack =============================
[ACADLT_LANGPACK]
PRODUCT_NAME=AutoCAD LT® 2018 Language Pack
EXE_PATH=%platform%\%lang%\acadlt\AcadLTLP\AcadLTLP.msi
EXE64_PATH=%platform%\%lang%\acadlt\AcadLTLP\AcadLTLP.msi
ADMIN_INSTALL=YES
IGNORE_FAILURE=YES
LOG=%tmp%\Autodesk AutoCAD LT 2018 LangPack Install.log
2. Use task manager to kill the setup process after AutoCAD LT 2018 gets installed, so that the installer cannot initiate the rollback.
I guess you can also fake it in the registry, the keys should exist there before the rollback starts.
@Mark.Lancaster @TravisNave A new failure, almost there before it rolled back
Tried this tip in the SETUP.INI in the Language Pack section
IGNORE_FAILURE=YES
It looks like that is what caused this 'allied' failure. So we can't do that anymore.
Zip of log files attached.
Open to other ideas.
I know that we thrown a lot of at you.. But can you run Microsoft Fixit and make sure the LT language package is not there.. Usually when you see that message about allied product means the language pack has already been installed.
Mark Lancaster
@pendean, I agree with Mark that it is probably a remnant of a failed install. I would first try to find it in the registry and delete the keys containing AutoCAD LT 2018 and the AutoCAD LT 2018 Language Pack - English from the regedit location here:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\
Once you get to that key, just hit F3 and search for "AutoCAD" and that should get you enough to find the 2018 keys. You'll want to get rid of all the 2018 stuff and then try to reinstall.
Keep us posted on your findings.
Hello @pendean,
You have received some great feedback, I will reach out to you on PM to provide some more and report back on our findings if we can resolve the issue.
Thank you.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
INSERT EXPLETIVE HERE before admin deletes it 🙂
@TravisNave @Mark.Lancaster @natasha.l thank you for trying. While all the advice is top notch, it's all a repeat of previous replies, not much new is being added. Time for the nucular option!
On my lunch break I simply booted Windows into SafeMode with Network (and Microsoft Installer enabled): LT2018 installed fully in about 10-minutes. Reboot and all seems well. Whatever prevented LT2018 (but not R2018) from installing was halted apparently.
Moral of the story: LT2018 installer is indeed different from R2018's installer. Some errant SOB code that got caught up in something I have running on my PC I'm sure.
Good topic to revive my blog with... .
Hello @pendean,
Woo hoo happy to hear it! That's great.
Natasha
Helpful Links:
I work for Unilogic, a IT-service company in Holland.
One of our customers asked us to install AutoCAD 2018LT via the Administrative Image and our own Software Packaging System (Unilogic Packaging System).
I ran into exact the same issues as Dean Saadallah, and i think i have found the underlying reasons (and the weird solutions).
After reading this forum post and doing some Google search i didn't find any real answers, so i started to analyse the problem myself.
Via the SCCM commandline file the administrative setup generates i had the oppurtunity to reproduce the install the administrative setup does, only now from the commandline while disabling the 'silent' en 'quiet' feautures, so i could see the output.
The administrative setup does about 15+ installs in the background.
I ran into 3 underlying reasons the administrative setup has, without any apropiate error handling (it seems just to stop at a moment):
1. One of the installers actually gives the feedback that the explorer.exe should be closed. Now you should expect that closing the Windows Explorer windows will do the job (just like some Adobe installers require), but that didnt work. After looking into the PID the setup said it wanted to be closed, i found it was the explorer.exe as System (thus the System Shell). I just killed exactly that PID (the las explorer.exe that was running) and the same setup came up with the next error, see item 2.
2. The same installer spawned a error, that the proces (PID) of the Windows Task Manager should not be running while executing the setup. Again, i followed up the error and suggested solution and killed exactly that PID (Taskmanager).
3. After item 1 and 2 all install commands finished succesfully, but at the last item (the streamed update) i again ran into an error.
The last item (the AutoCAD update streamed within the administrative install) has a wrong path in it. It expects the update starts from the path it was downloaded (c:\temp in our case) while building the administrative image. When we deploy the administrative image, we copy it to our own directory structure, resulting in a other working direct (c:\unilogic\installers\007731). Normally all paths should be relative, so if the working directory is ok, everything should be fine. In the case of the streamed update in the administrative image, the path is nog relative but absolute, so when you deploy the administrative image on another system where it was build an you use another working directory it failes.
Solutions we applied, so we can deploy AutoCAD 2018LT whitout 'hanging'
1. Kill all explorer.exe processes before installing the administrative image, after the install is finished, spawn the explorer.exe againg (so the user has its System shell - The Windows start button, Tray icons, etc back)
2. Check for a taskmgr.exe process, if it exists, kill all taskmgr.exe processes before installing the administrative image.
3. Copy the update (AutoCAD_LT_2018.0.1_Update_32bit.exe in our case) to the directory the administrative expects its in (the absolute path).
