2023 Network Deployment - Installation quits with error 1327
- Mute
- Permalink
- Report
Okay, so I am creating a network deployment of AutoCAD Electrical so we're all working with the same libraries and support files. I have the network deployment all set up and good to go in terms of running the shared content batch file and copying everything over to where I want it.
The problem is that when I go to install AutoCAD Electrical itself using the Install batch file, It will run, and then it will quit with an error. Checking the log file, I see this:
2022-09-02T00:56:16.266 [Deployment: 5072, single] [RMT0004 INFO] Deployment started...
2022-09-02T00:57:30.495 [Deployment: 5072, single] [RMT0004 INFO] Deployment started...
2022-09-02T00:57:39.834 [Deployment: 5072, single] [RMT0004 INFO] Installing: ODIS Installer
2022-09-02T00:57:39.837 [Deployment: 5072, single] [RMT0004 INFO] Installing: Microsoft .NET Core Runtime 3.1.10
2022-09-02T00:57:39.839 [Deployment: 5072, single] [RMT0004 INFO] Installing: Microsoft ASP.NET Core 3.1.10 Shared Framework
2022-09-02T00:57:39.841 [Deployment: 5072, single] [RMT0004 INFO] Installing: AutoCAD 2023 Shared Language Pack - English
2022-09-02T00:57:39.845 [Deployment: 5072, single] [RMT0004 INFO] Installing: ACA & MEP 2023 Object Enabler
2022-09-02T00:57:39.846 [Deployment: 5072, single] [RMT0004 INFO] Installing: AutoCAD 2023 Shared
2022-09-02T00:57:39.848 [Deployment: 5072, single] [RMT0004 INFO] Installing: Autodesk AutoCAD 2023 - English
2022-09-02T00:57:39.849 [Deployment: 5072, single] [RMT0004 INFO] Installing: AutoCAD 2023
2022-09-02T00:57:39.851 [Deployment: 5072, single] [RMT0004 INFO] Installing: Autodesk Licensing Installer 1.0
2022-09-02T00:58:27.554 [Deployment: 5072, single] [RMT0004 INFO] Installing: AutoCAD Electrical 2023
2022-09-02T00:59:14.321 [Deployment: 5072, single] [RMT0004 INFO] Installing: AutoCAD Electrical 2023 Language Pack - English
2022-09-02T00:59:14.324 [Deployment: 5072, single] [RMT0004 INFO] Installing: ACADE Private
2022-09-02T00:59:14.327 [Deployment: 5072, single] [RMT0004 INFO] Installing: AutoCAD Electrical 2023 Content Pack
2022-09-02T00:59:34.883 [Deployment: 5072, single] [RMT0004 INFO] Installing: AutoCAD Electrical 2023 Content Language Pack - English
2022-09-02T00:59:36.475 [Deployment: 5072, single] [RMT0004 ERROR] 1603: Fatal error during installation.
2022-09-02T00:59:57.277 [Deployment: 5072, single] [RMT0004 ERROR] {B80FBC28-6676-358B-AB4B-89FA3AA4F868} : 1603
2022-09-02T00:59:57.277 [Deployment: 5072, single] [RMT0004 ERROR] Deployment failed!
2022-09-02T00:59:57.277 [Deployment: 5072, single] [RMT0004 INFO] Error context: MSI (s) (E4:80) [00:59:36:351]: Product: AutoCAD Electrical 2023 Content Language Pack - English -- Error 1327. Invalid Drive: W:\ Action ended 0:59:36: CostFinalize. Return value 3. Action ended 0:59:36: INSTALL. Return value 3. Property(S): ROAMABLEROOTFOLDER = %HOME%\AppData\Roaming\Autodesk\AutoCAD Electrical 2023 Content Language Pack - English\R24.2\enu\ Property(S): ROAMING = 1 Property(S): ACAD_NOTEPAD_PATH = C:\WINDOWS\system32\notepad.exe Property(S): DOTNET_INSTALLED = #1 Property(S): DOTNET4_VERSION = 4.8.04084
2022-09-02T00:59:57.277 [Deployment: 5072, single] [RMT0004 INFO] Please explore possible solution from: https://knowledge.autodesk.com/search-result/caas/downloads/content/autodesk-licensing-service-relea...EML
2022-09-02T01:01:31.230 [Deployment: 5072, single] [RMT0004 INFO] Deployment exits
I have gone through and checked everything I can think of, and nothing seems to work to alleviate the issue. I double and triple checked all the file paths, I made sure that every last bit of Autodesk product was completely removed from the machine. I even went as far as to create an all new deployment, but still I get this error, and I cannot figure it out.
Can anyone help?
Topic title has been edited to improve findability by @alina.balkanskaia. Original: 2023 Network Deployment - AutoCAD Electrical will not install.
