Technical support telephone number in the UK
Does any one have a telephone number for the UK for technical support
AutoCAD LT Will not complete the initial install
hanging on checking licence.
TravisNave
You should have a support number in your https://accounts.autodesk.com if you have advanced support.
In the mean-time, I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
