Help PLEASE, CFD FLEX
I cannot open Autodesk CFD 2016 :/.
I've encountered this issue before, I think I resolved it through uninstalling the programme, then signing in to autodesk and re-installing the software from my autodesk account, there may be an easier way to fix it but I believe that is what I did to resolve it
Jon.Wilde
I would say there should be a better way 🙂
Ideally the Installation and Licencing team should be able to help (I will move this over to their forum for you now)
Some questions that will help them:
Is your licence local or remote?
Did your licence work before?
Once they are in touch, it might be good to share the licence also.
Jon
TravisNave
Do you get any errors?
Please list your version, OS, etc.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Mark.Lancaster
@Anonymous
This posting is almost a month old..  Did you get his resolved?   If not your first image is indicating that you have a network license of CFD.  So did you generate a license file and setup the license manager?
Mark Lancaster
