Revit 2021 Updates
Revit 2021 Updates
RSomppi
Mentor Mentor
Message 1 of 8
Revit 2021 Updates
RSomppi
I'm looking for updates to 2021 and cannot find any through my account or otherwise. We have a number of people that need to update and none of us can find any of them.
Can someone provide a direct link to them, please?
Replies (7)
Message 2 of 8
TravisNave
You might try the new Autodesk Access update app that replaced the old Desktop App.  That might get you the updates that you want.
https://emsfs.autodesk.com/utility/odis/1/installer/latest/AdODIS-installer.exe
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 8
RSomppi
Yeah, no, I have that. The updates are not showing. I had to get the 2021.1.8 .exe from Autodesk by opening a support ticket. It does not appear to be available anywhere. I got it for my machine a while back through normal update notifications but others on my team didn't have 2021 installed and upon installation, there were zero updates available. Something similar is happening with 2022 also. It's wierd.
Message 4 of 8
pendean
Community Legend
Community Legend
Yeah, no, I have that. The updates are not showing...
ACCESS is slow to update itself: you can to redownload/reinstall more often to grab the latest and greatest.
@RSomppi wrote:
I had to get the 2021.1.8 .exe from Autodesk by opening a support ticket. It does not appear to be available anywhere....
Indeed, Autodesk seems to have decided to make that unavailable for some reason, if true nothing like ACCESS or anything else is going to just link to it easily either
https://manage.autodesk.com/products/RVT?version=2021&platform=WIN64&language=EINT
https://manage.autodesk.com/products/updates/?sortField=releaseDate&sortOrder=desc&recent=90
Message 5 of 8
TravisNave
Yeah, the updates are not showing for me either.  Even the direct links to the files are missing.  Interesting.
Autodesk Forums:
Message 6 of 8
rvtlt2023desktopsu-sim
Community Visitor
Community Visitor
We experienced a small issue during the publishing of this update, which caused the update to remain displayed in Autodesk Access after it was installed.  We have made the necessary correction and this update should once again be available via manage.autodesk.com or Autodesk Access.
Also, all changes were on the backend so you will not experience problems if you had already installed this update during the short time it was available.
Tony Michniewicz
Autodesk Delivery Team
Message 7 of 8
RSomppi
This issue still persists. I have users that cannot update to the build that is on my machine. Two or three versions are affected 2020 - 2022. I thought this might get straightened out with some time but it hasn’t.
What is the best course of action here? I’m pretty sure the updates that I have do not allow me to roll them back. I remember seeing something about that in the release notes. We have a number of very large projects that are being worked on by different builds. As the person tracking this information and finding solutions, it makes me uncomfortable that we cannot all be on the same build so that is not a potential issue. Any suggestions would be appreciated.
We are about to start using 2023. I can only hope that we can all get the same build.
Message 8 of 8
DarrenP
You can try contacting Autodesk here: https://www.autodesk.com/support/contact-support?startHelpBranch=post-purchase/download-software
DarrenP
