Announcements
Requesting a server license file with multiple products
postmah
postmah
We changed the mac address of our License server and need a new license file with multiple products created with the new mac address.  Any help would be appreciated.
Thank you
Mark.Lancaster
@postmah
To generate a license file (pick one)
1.  The contract manager or software coordinator for you subscription can log into their Autodesk Account and select Generate License file link
2.  Go to the Autodesk Register Once Web site and follow the prompts.  With Register Once you have to repeat the process for each network serial # that you have and then combine the license file at the end.
3.  Contact your reseller and they will do it for you.
4.  Contact Autodesk here and they will do it as well.
In all cases you will need the name and MAC address of the machine that is hosting the license file.   One final thing, you must update your license manager to version 11.13.1.2 (https://knowledge.autodesk.com/customer-service/network-license-administration/get-ready-network-lic...)
Mark Lancaster
rkmcswain
I like #3 the best. Make them earn their keep 😄
R.K. McSwain     | CADpanacea | on twitter
TravisNave
It'd be a lot easier to simply change the MAC back to the old one. If this is a VM, then it should be fairly easy to hard-code in your MAC.  In fact, you should absolutely do this for any virtual server if you are using the NLM.  Otherwise, you will have this problem again.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
