Revit 2025: Downloading process frozen at 97% for quite a long time
aya_irshead
Observer Observer
Message 1 of 11
aya_irshead
Observer
Observer
Hi guys,
I’m trying to install revit 2025, but when I tried the first time the downloading process froze at 97% for quite a long time, so I tried to delete it and download it again but my pc keeps telling me that I still got it.
- I deleted it from settings as will
- I still have revit 2023
Can you guys help me understand what’s wrong? And what to do about it?
[The subject line of this post has been edited for clarity by Community Manager. Original: Problem with installing Revit 2025
Replies (10)
Message 2 of 11
pendean
Community Legend
Community Legend
@aya_irshead wrote:
Hi guys,
I’m trying to install revit 2025....
Try this direct 10+GB single installer file download instead
https://forums.autodesk.com/t5/installation-licensing/2025-product-download-links/m-p/12663620#M2776...
Message 3 of 11
mdavis22569
Can you try reviewing the following too:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Autodesk-Revit-202...
The key for Revit 2023 is
"{7346B4A0-2300-0510-0000-705C0D862004}"
Mike Davis
Message 4 of 11
four2una
Community Visitor
Community Visitor
Hi, I'm facing exactly the same problem- it got to 97% and stopped for 4 hours...Can you please tell me what did you do?
Message 5 of 11
mdavis22569
Hi @four2una
Did you try the direct download links in the 2025 folder?
Clean out the %temp% folder while they are downloading.
Mike Davis
Message 6 of 11
TravisNave
Let it run overnight if you have to.  It will complete, you just have to be patient.  Constantly cancelling the installer will only cause additional installation problems for you.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 7 of 11
engkahhat
Community Visitor
Community Visitor
Hi guys,
I’m trying to install Revit 2025, but when I am trying the installing process froze at 97% for quite a long time as 4-5 Hours. What I should I do, do you recommend stop/ cancelling installation. Please let me know.
Message 8 of 11
Simon_Weel
Indeed incredibly annoying. If you check the installation logs, you'll notice it's waiting for a pipe to do something that never happens. If the Cancel button is available, click it. And if you the get the warning 'Are you sure' or something like that, click Resume. Most of the times this will get the installer going again.
Message 9 of 11
terry2C7N2
Community Visitor
Community Visitor
This did the trick for me, haha. I had v4.3 stuck at 98% for about 20 minutes. Click 'Cancel', then 'Continue', and hop right to.
Message 10 of 11
deepti_bhardwaj
Hello @aya_irshead
Thanks for your patience! Here's a clear path forward to resolve the Revit 2025 installation issue, where your PC still detects Revit even after uninstalling:
Why This Happens
Even after uninstalling via Settings, residual registry entries and leftover files can cause Windows and Autodesk installers to think Revit 2025 is still installed.
Step-by-Step Fix
1. Use Microsoft’s FixIt Tool
This tool helps remove stubborn remnants of uninstalled software.
  • Download Microsoft Program Install and Uninstall Troubleshooter (For reference: Software is already installed)
  • Run the tool → Select Uninstalling
  • Choose Not Listed → Enter this product code for Revit 2025:
  {7346B4A0-2500-0510-0000-705C0D862004}
2. Clean Registry Entries (Advanced)
If you're comfortable editing the registry:
  • Open regedit
  • Navigate to:
  HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
  • Find and rename/delete the key matching Revit 2025
⚠️ Backup your registry first before making changes.
3. Delete Leftover Folders
Use File Explorer to delete these folders if they exist:
C:\Program Files\Autodesk\Revit 2025
C:\ProgramData\Autodesk\RVT 2025
C:\Users\<YourUsername>\AppData\Local\Autodesk\Revit\Autodesk Revit 2025
C:\Users\<YourUsername>\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2025
Also, clean the %TEMP% folder:
  • Press Win + R, type %TEMP%, and delete all contents
4. Reinstall Revit 2025 Using Direct Installer
Instead of using Autodesk Access or Web installer, try the full installer:
  • Revit 2025 Direct Download Links (manage.autodesk.com>Products & Services>Revit>Click on the dropdown right next to "Install" option> Click on the drop down again>slecet "Direct Download")
Did you find this reply helpful? If so, please use the "Accept as Solution"
Message 11 of 11
mari.shimode
I have marked @deepti_bhardwaj's reply as an accepted solution so people who have the same issue can find it easily.
Mari Shimode
