Old Registry Entrys
Old Registry Entrys
supportXLQJL
Observer Observer
Old Registry Entrys
supportXLQJL
Observer
Observer
I have in Baramundi Software much old software entrys f.e.  Autodesk Genuine Service Version 2.20, 3.011, 7.4.0.223 and installed on all PCs ist the 7.4.0.223.  The same Autodesk Access, Autodesk ReCap and so on. What registry entry I musst delete that Baramundi doesn't find the old versions?
Kind regards
Matthias
TravisNave
Are you trying to remove old entries in the registry so that old uninstalled versions are not coming up on an audit?
Generally speaking, there are 3 main locations where Autodesk programs are tracked.
The Control Panel registration is located here:
HKEY_LOCAL_MACHINE\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVERSION\UNINSTALL
You would have to do a search under that key for each Autodesk product.
 And the application registrations for the user/computer for each product are found here:
HKEY_LOCAL_MACHINE\SOFTWARE\AUTODESK
HKEY_CURRENT_USER\SOFTWARE\AUTODESK
You should be able to find and remove the appropriate keys under those for the products that you want to remove.
I would backup the registry to a .reg file before making any changes first so that you can restore them if you have problems.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
handjonathan
Hi @supportXLQJL
Thanks a lot for posting your question to the forums!   Has the solution suggested by @TravisNave helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
