Notebook vs Laptop best Notebook with shared graphics 64 bit
tech3design
tech3design
the best 64 bit notebook , not laptop that has a good shared graphics component. no question only recommendation please. There are only a few out there to choose from. HP, Dell, Tosh...
The Intel HD graphics will not cut it.
Products to be used,
Revit moderate use
AutoCAD heavies used with large data sets bla, blah, bla,,,,
What is the shared graphic components  that works be best. only the knowledgeable reply, please.
The Dell Precision is great but to big,
Looking for as small as I can get in a notebook....
Can't wait to see what you respond to this one.
Thank you,
TravisNave
Autodesk puts together a list of the recommended hardware for their products here:
http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534&results=1&stype=system&produc...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
tech3design
I already check, they are out dated. They are not updating it anymore. any others that would like to chime in .....
Thank you,
If i am not wrong, laptop has lots of advantage compared to notebook right?
