Flexnet - Cannot connect ... (-15,10:10061 "WinSock: Connection refused")
Ive got a customer that is getting the error "Cannot connect to license server system. (-15,10:10061 "WinSock: Connection refused")" They have a license file that was recently created.
They also have Geomagic and Leica licenses running on the same server. Not sure if that is causing an issue or not. Below is a status inquiry and a log file. I double checked that ports are open. Any Ideas?
Status
Flexible License Manager status on Wed 1/28/2015 12:48
[Detecting lmgrd processes...]
License server status: 27006@Mother
    License file(s) on Mother: C:\Program Files (x86)\3D Systems\Geomagic license server Utility\Bin\GSLicense.lic:
lmgrd is not running: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name:   10.0.1.190
License path:  27006@Mother;
FLEXnet Licensing error:-15,10.  System Error: 10061 "WinSock: Connection refused"
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
11:24:35 (lmgrd) -----------------------------------------------
11:24:35 (lmgrd)   Please Note:
11:24:35 (lmgrd)
11:24:35 (lmgrd)   This log is intended for debug purposes only.
11:24:35 (lmgrd)   In order to capture accurate license
11:24:35 (lmgrd)   usage data into an organized repository,
11:24:35 (lmgrd)   please enable report logging. Use Macrovision's
11:24:35 (lmgrd)   software license administration  solution,
11:24:35 (lmgrd)   FLEXnet Manager, to  readily gain visibility
11:24:35 (lmgrd)   into license usage data and to create
11:24:35 (lmgrd)   insightful reports on critical information like
11:24:35 (lmgrd)   license availability and usage. FLEXnet Manager
11:24:35 (lmgrd)   can be fully automated to run these reports on
11:24:35 (lmgrd)   schedule and can be used to track license
11:24:35 (lmgrd)   servers and usage across a heterogeneous
11:24:35 (lmgrd)   network of servers including Windows NT, Linux
11:24:35 (lmgrd)   and UNIX. Contact Macrovision at
11:24:35 (lmgrd)   www.macrovision.com for more details on how to
11:24:35 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
11:24:35 (lmgrd)   for your enterprise.
11:24:35 (lmgrd)
11:24:35 (lmgrd)
11:24:35 (lmgrd)
11:24:35 (lmgrd) pid 9320
11:24:35 (lmgrd)
11:24:35 (lmgrd) WARNING: 2 license server systems specified in license file.
11:24:35 (lmgrd) (an even number of server systems is probably a mistake.)
11:24:35 (lmgrd) You may have duplicated a SERVER line by mistake
11:24:35 (lmgrd)
11:24:35 (lmgrd) Detecting other license server manager (lmgrd) processes...
11:24:35 (lmgrd) Done rereading
11:24:35 (lmgrd) FLEXnet Licensing (v11.3.0 build 28877) started on MOTHER (IBM PC) (1/28/2015)
11:24:35 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
11:24:35 (lmgrd) US Patents 5,390,297 and 5,671,412.
11:24:35 (lmgrd) World Wide Web:  http://www.macrovision.com
11:24:35 (lmgrd) License file(s): C:\Leica_License\mother.lic
11:24:35 (lmgrd) lmgrd tcp-port 27000
11:24:35 (lmgrd) Starting vendor daemons ...
11:24:35 (lmgrd) Started CYRAKEY (pid 16308)
11:24:35 (lmgrd) Starting vendor daemon at port 2080
11:24:35 (lmgrd) Using vendor daemon port 2080 specified in license file
11:24:35 (lmgrd) License server manager (lmgrd) startup failed:
11:24:35 (lmgrd) File not found, adskflex.exe
11:24:35 (CYRAKEY) FLEXnet Licensing version v11.3.0 build 28877
11:24:35 (CYRAKEY) Invalid license key (inconsistent authentication code)
11:24:35 (CYRAKEY)    ==>INCREMENT CY_REGISTER CYRAKEY 8.0 permanent 1 81F73AF4992E BORROW=768 \
                        SN=0101244
11:24:35 (CYRAKEY)    ==>INCREMENT CY_REGISTER CYRAKEY 8.0 permanent 1 21FA3BF49C2E BORROW=768 \
                        SN=0101259
11:24:35 (CYRAKEY)    ==>INCREMENT CY_REGISTER CYRAKEY 8.0 permanent 1 21F83BF49A2E BORROW=768 \
                        SN=0101257
11:24:35 (CYRAKEY)    ==>INCREMENT CY_PUBLISHER CYRAKEY 8.0 permanent 1 4A2F0A0AD54C \
                        SN=0101248
11:24:35 (CYRAKEY)    ==>INCREMENT CY_MODEL CYRAKEY 8.0 permanent 1 324F04C38C51 SN=0101240
11:24:35 (CYRAKEY)    ==>INCREMENT CY_MODEL CYRAKEY 8.0 permanent 1 324F04C38E4F SN=0101242
11:24:35 (CYRAKEY)    ==>INCREMENT CW_ACAD_PRO CYRAKEY 4.2 permanent 1 1D7C10E9F8E5 SN=0101250
11:24:35 (CYRAKEY)    ==>INCREMENT CW_REVIT CYRAKEY 1.0 permanent 1 B470F261AAE7 SN=0101261
11:24:35 (CYRAKEY) License server system started on MOTHER
11:24:35 (CYRAKEY) No features to serve, exiting
11:24:35 (CYRAKEY) EXITING DUE TO SIGNAL 27
11:24:39 (lmgrd) CYRAKEY exited with status 27 (No features to serve)
11:24:39 (lmgrd) CYRAKEY daemon found no features.  Please correct
11:24:39 (lmgrd) license file and re-start daemons.
11:24:39 (lmgrd)
11:24:39 (lmgrd) This may be due to the fact that you are using
11:24:39 (lmgrd) a different license file from the one you expect.
11:24:39 (lmgrd) Check to make sure that:
11:24:39 (lmgrd) C:\Leica_License\mother.lic
11:24:39 (lmgrd) is the license file you want to use.
11:24:39 (lmgrd)
11:28:15 (lmgrd) Rereading license file... Requested from serveradmin@Mother
11:28:15 (lmgrd) Reread: Started CYRAKEY (pid 15460)11:28:15 (lmgrd) Shutting down adskflex pid=4294967295 because reread removed daemon
11:28:15 (CYRAKEY) FLEXnet Licensing version v11.3.0 build 28877
11:28:15 (CYRAKEY) Server started on MOTHER for:     CY_REGISTER
11:28:15 (CYRAKEY) CY_PUBLISHER                  CY_MODEL                        CW_ACAD_PRO
11:28:15 (CYRAKEY) CW_REVIT
11:28:16 (lmgrd) Can't connect to the license server system. Shutdown adskflex failed.
11:28:16 (lmgrd)          Cannot connect to license server system. (-15,10:10061 "WinSock: Connection refused")
11:28:25 (CYRAKEY) Vendor daemon can't talk to lmgrd (Cannot read data from license server system. (-16,287))
11:28:25 (CYRAKEY) EXITING DUE TO SIGNAL 28
DarrenP
check to see if your firewall is not blocking ports 2080 and 27000~27009
Also, verify that the MAC address listed in your .LIC file matches the address listed on the System Settings tab of LMTOOLS
i also noticed your running 11.3
for 2015 autodesk products autodesk requires 11.12 of flex LM
DarrenP
TravisNave
Darren is right, and the debug log appears to be for another product.  CYRAKEY is not ADSKFLEX.  Possibly a license manager conflict.  You might need to show the log file for the Autodesk daemon if it has been started.
Looks like it can't find it.  Did you combine license managers and forget the adskflex.exe?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
