error code when installing
I downloaded the free trial of Autocad LT.  After the file downloads, I run it and it creates a second larger install file.  When I run that install file I get an error message:
The procedure entry point ucrtbase.terminate could not be located in the dynamic link library api-ms-win-crt-runtime-I1-0-1.dll
Thanks for any help you can provide.
Alan
Mark.Lancaster
alan
Welcome to the community and hopefully my (or someone else) reply will be beneficially to you.
As a reminder, this is a world wide (public) user forum where users are assisting others. In addition do not post, attach screen shots, or share any personal information (such as your serial #) here.
Not sure what operating system you have but see @TravisNave reply (last one) regarding this: http://forums.autodesk.com/t5/installation-licensing/acad-17-lt-system-error/td-p/6272812
Mark Lancaster
i have the same issue when trying to Install PRDSP 2017. If i choose download option then install works OK.
attempting 64 bit install on Windows 7 Pro SP1.
TravisNave
See if it helps if you install this Windows Update:
https://support.microsoft.com/en-us/kb/2999226
Please let me know if it does as I am continuing to research how to resolve this new error.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
