Deploying Updates via Network Push
i have over 100 computers on my network running Autocad and Revit.
We have created a deployment image a few months ago and deployed out to all workstations.
since then we have had some users manually run application manager to update with services packs etc..
i want to ensure that all workstaions have the same version of both Autocad and Revit, is there a way to package all updates and service packs and deploy them out to the workstations without having to go to each machine and clicking update?
batch file?
GPO?
Chris A
TravisNave
You should be able to push an update via GPO or even a login script file.  You will also want to patch your deployment afterwards.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Am i doing something wrong? i have added all the MSI and MST like suggested in the deployment article but i am getting errors when i try to launch the application on my windows desktop.
i am pushing this out via GPO and it sits and installs everything, appears to be fine on the workstation but i get errors when i try to launch. i have tried restarting the workstation but it doesnt make any differences.
i have attached the GPO files attached.
