Can't Run A-desk .exe Files
I am putting this here because I had issues with install files earlier. Now it is an exe that comes with C3D: Autodesk.Aec.Content.CatalogEditor.exe I thought that was a CAD Manager group, but I guess no longer.
There is something wrong with Autodesk exe's in that they start but stop a few seconds later (you can watch it happen in Task manager).
From Windows Event Viewer, Application, there are four events being logged:
Information:
The Software Protection service has stopped.
Error:
Application: Autodesk.Aec.Content.CatalogEditor.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileNotFoundException
Stack:
at Autodesk.Aec.Content.CatalogEditor.App.Main()
Error:
Faulting application name: Autodesk.Aec.Content.CatalogEditor.exe, version: 1.16.0.4, time stamp: 0x52a80cc5
Faulting module name: KERNELBASE.dll, version: 6.1.7601.18798, time stamp: 0x5507b87a
Exception code: 0xe0434352
Fault offset: 0x000000000001aaad
Faulting process id: 0xcd8
Faulting application start time: 0x01d086ac192556de
Faulting application path: C:\Program Files\Autodesk\AutoCAD 2015\C3D\Autodesk.Aec.Content.CatalogEditor.exe
Faulting module path: C:\Windows\system32\KERNELBASE.dll
Report Id: 56fe1194-f29f-11e4-b1b4-002564c0f7b0
Information:
Fault bucket 162640593, type 20
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: Autodesk.Aec.Content.CatalogEditor.exe
P2: 1.16.0.4
P3: 52a80cc5
P4: KERNELBASE.dll
P5: 6.1.7601.18798
P6: 5507b87a
P7: e0434352
P8: 000000000001aaad
P9:
P10:
C:\Users\wudar\AppData\Local\Temp\WERF008.tmp.WERInternalMetadata.xml
These files may be available here:
C:\Users\wudar\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_Autodesk.Aec.Con_e9ae572303e9b5b259e62e19fadb53dba2d97c0_13b8034a
Analysis symbol:
Rechecking for solution: 0
Report Status: 0
Please advise. I need to be able to run A-desk exe's. Files from Autodesk are the only files I have ever experienced this with on this machine, or ever.
Civil 3D 2015 SP2
Windows 7 Enterprise SP1
THANKS
