Bandwidth Issues - dds.autodesk.com
We are currently deploying AutoDesk Inventor 2024 via our chosen deployment method, SCCM. Whilst we have the package successfully configured on our network and we deploy to our endpoints without any issues, we seem to have run into an issue with bandwidth surrounding software updates post-deployment.
Upon investigation, it appears that every endpoint is downloading some form of update for Inventor (which is typically around 1-3GB in size) and this is having a huge strain on our broadband (we have over 400 endpoints with the software installed) and the rest of our environment.
As a temporary measure, we have blocked updates at the firewall level by blocking the FQDN, dds.autodesk.com. This isn't and shouldn't be seen as a permanent solution as we have a centrally managed firewall and filtering system so this block is only valid until an update is pushed out from head office.
My question is, is there a way that updates can be suppressed from the package creator, we don't want (or need) AutoDesk Inventor 2024 to automatically update, our preferred method for software updating is manual so we can keep track of versions and deployment schedules.
As you can see from the below screenshots, the traffic is coming from autodesk.com but when doing a deeper dive into the traffic report, we have noticed that the updates are coming from dds.autodesk.com so we have had to put a temporary block for this FQDN.
