Announcements
Autocad LT 2015 is not installing
I have a DELL latitude E6510 with the following specifications:
Processor: Intel (R) Core (TM) i5 CPU  M450 @ 2.40GHz
Ram: 4Gb
OS: Windows 7 Professional 32 bit.
When trying to install AutoCAD LT 2015 it is giving me the below error extracted from the installation log file
2014/10/5:07:38:47 Ivan LAPTOP Install Autodesk® AutoCAD LT® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/10/5:07:38:52 Ivan LAPTOP Rollback Autodesk Content Service Language Pack Succeeded
2014/10/5:07:39:03 Ivan LAPTOP Rollback Autodesk Content Service Succeeded
2014/10/5:07:39:25 Ivan LAPTOP Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/5:07:40:01 Ivan LAPTOP Rollback Autodesk Material Library 2015 Succeeded
2014/10/5:07:40:02 Ivan LAPTOP Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/5:07:40:02 Ivan LAPTOP Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
I am also attaching the log file. Can you kindly help me install the software.
TravisNave
 I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
