Announcements
Autocad 2016 install problems: Fatal error: Unhandled e0434352h Exception at fbe
I downloaded autocad 2016 from torrent but I couldn't start the program. When I try a message came all the time.
FATAL ERROR: Unhandled e0434352h Exception at fbe
I use 64-bit windows 7
Could somebody help me please?
Mark.Lancaster
@Anonymous
Welcome to the community and hopefully my (or someone else) reply will be beneficially to you.
Since you’re new to the community I just wanted to inform you this is a worldwide (public) user forum where users are assisting others. For any future postings you may do, please do not include any personal information (such as your serial #) in anything that you share (including screen shots & attachments) with us.
Fatal errors in AutoCAD could mean many things...
  • I suggest cleaning out your temp folder and delete as many files and folders as possible.
  • Click Windows Start and type %TEMP% in the search box.
  • Select all files & folders and delete them.
  • Certain temporary files and folders will not be able to be deleted because they are currently in use by the OS and/or any other applications you currently have open. Skip any of these files/folders and continue on with the deletion process.
Launch your application and report back on your progress.
Mark Lancaster
Alfred.NESWADBA
I would start downloading the software from an official Autodesk download site like Autodesk Virtual Agent >>>click<<<.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
TravisNave
Downloading from torrents implies that you are doing something  that you are not supposed to be doing.  Smiley Wink
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
i followed your instructions on deleting temp files. It didn't still work. I remember reading this post
Re: Fatal Error AutoCAD 2016
04-06-2015 03:19 PM in reply to: mahmutdemirbas
I did this and it did not worked. After doing this I noticed that we have different fatal error.
 Before resorting to this forum I installed and uninstalled the program perhaps 3 or 4 times. All has the same problem.
I tried downloading the autocad from autodesk website. I can;t install it because of "Communication failure"
Mark.Lancaster
@Anonymous
IF you have purchased your AutoCAD from Autodesk and have a proper serial # then review the information I have below the line/above my signature and follow those steps to download and install your application. Good luck with the installation.
Mark Lancaster
