api-ms-win-crt-runtime-l1-1-0-dll
Have a nice evening.................... can I ask? api-ms-win-crt-runtime-l1-1-0-dll is missing when installing autocad 2017 and also having windows 7 in my PC? what can I do?
Otto
Hello aggelamp and welcome to the Autodesk community!
It looks like you are looking for information related to the error message: "api-ms-win-crt-runtime-l1-1-0.dll is missing". Community members with similar questions found the following article(s) useful:
api-ms-win-crt-runtime-l1-1-0.dll is missing - AutoCAD 2017
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
I am trying method 2
but
no Windows Kits
folder exists
I will try also once more
and we will see
Angeliki
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I suggest following method one as described here:
1.  Go to Windows Update and make sure that your computer is fully updated.  The Universal CRT should be delivered by this method.
2.  If not, manually download and install the Microsoft Visual C++ Redistributable for your version of Windows (likely x64)
For Windows x64:
http://download.microsoft.com/download/9/3/F/93FCF1E7-E6A4-478B-96E7-D4B285925B00/vc_redist.x64.exe
For Windows x86:
http://download.microsoft.com/download/9/3/F/93FCF1E7-E6A4-478B-96E7-D4B285925B00/vc_redist.x86.exe
3.  You might have to choose uninstall first before you can install the above downloads because of previous failed installs.
4.  Reboot then try to launch AutoCAD 2017 again.
I will also move this thread to I&L for more options.
John Vellek
TravisNave
Skip Method 2 for now and try my solution #2 in the original thread:
http://forums.autodesk.com/t5/installation-licensing/api-ms-win-crt-runtime-l1-1-0-dll-is-missing-au...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
